SPI Interfacing
Results 1 to 9 of 9
Thread: SPI Interfacing
    Jun 2006
    Default SPI Interfacing
    Hello all,
    Just writing to find out if there is any collection of information on SPI commands out there. I am using a PIC16F88 to interface with an ISD1700 Winbond Chipcorder and since SPI is standard with the F88 I thought that there would be a supported SPI command or some sort of Include file... Defines or even an SPI page in the manual but I didn't see anything that supported SPI in the PBP or Proton manuals... I did find some info on a few websites out there on the Web but I would have thought it was covered somewhere in one of the manuals?? It would be nice to see a list of commands that would be useful to initialize the module in the PIC and use it to communicate... or am I overlooking something? I know that you can use ShiftIN and ShiftOUT for SPI but it would be nice to use SPI_??? Is this even possible in PBP or Proton?
    Thanks!
    May 2007
    Smile SPI methods
    I also looked for some examples last week but couldn't find any. I am using PIC 16F884. This has MSSP so life is actually very easy. I have extracted some snippets of code from my application so you can see how it works. The deeply indented code is not runnable but intended to demonstrate how the subroutines are called. I hope this helps. It runs my apps fine but I can't guarantee that it is the most efficient.
    I would be glad to explain if you need to contact me.
    'SPI setup
    pot_cs var PORTC.0 ' chip select
    a2d_cs var PORTC.1 'chip select
    amp_cs var PORTC.2 'chip select
    SSPCON.5=1 'enable SSP
    SSPCON.4=1 'Clock idles high bit name CKP
    SSPCON.3=0 ' bit 3 to 0 indicate clock speed. bit 0 set means clock = OSC/16 = 1.25 MHz
    SSPCON.2=0
    SSPCON.1=0
    SSPCON.0=1
    SSPSTAT.7=1 ' SPI Master mode
    SSPSTAT.6=0 ' data transmitted on rising edge of SCK
    TRISC.3 = 0
    TRISC.5 = 0
    vcount var word
    OUTPUT pot_cs
    OUTPUT amp_cs
    OUTPUT a2d_cs
    ' CODE TO CONTROL SPI POTENTIOMETER MicroChip MCP41050
    valuebyte = 128 ' VALUE OF POT 0 TO 255
    commandbyte = 17 ' bit 4 and 5 = command bits, bit 0 or 1 = channel select bit - 16 = write data, 1 = select CH0
    pot_cs = 0
    gosub sendspi
    pot_cs = 1
    'CODE TO CONTROL SPI AMPLIFIER MicroChip MCP6S21/2/6/8
    valuebyte = 0 'set gain INDEX
    commandbyte = 64 ' bit 5, 6 and 7 = command bits, bit 0 = register select - 0 = gain register, 1 = channel register
    amp_cs = 0
    gosub sendspi
    amp_cs = 1
    valuebyte = 0 ' select channel from input MUX
    commandbyte = 65 ' bit 5, 6 and 7 = command bits, bit 0 = register select - 0 = gain register, 1 = channel register
    amp_cs = 0
    gosub sendspi
    amp_cs = 1
    ' read SPI ADC MicroChip MCP3208
    valuebyte = 0
    commandbyte = 4 + 2 + channelnumber >> 2 ' SET BIT 2 HI FOR START BIT - bit 1 = single ended - bit 0 channelnumber may be 0 to 7
    secondbyte = channelnumber << 6 'D1,D0 shifted to top bits
    a2D_cs = 0
    gosub txrxspi
    a2D_cs = 1
    sendspi:
    SSPBUF = commandbyte
    PAUSEUS 10
    SSPBUF = valuebyte
    PAUSEUS 7
    txrxspi:
    PAUSEUS 10
    SSPBUF = secondbyte
    while SSPSTAT.0 = 0
    'spin
    WEND
    vcount = (SSPBUF & 15) << 8
    SSPBUF = valuebyte
    while SSPSTAT.0 = 0
    'spin
    WEND
    vcount = SSPBUF + vcount
    France
    Default SPI with a 16F88
    Hello,
    I have the same project for a friend who use SPI devices ..
    as far as I understand the 16F88 has a built in SPI option
    see datasheet copy
    10.2 SPI Mode
    This section contains register definitions and
    operational characteristics of the SPI module.
    SPI mode allows 8 bits of data to be synchronously
    transmitted and received simultaneously. To
    accomplish communication, typically three pins are
    used:
    • Serial Data Out (SDO) RB2/SDO/RX/DT
    • Serial Data In (SDI) RB1/SDI/SDA
    • Serial Clock (SCK) RB4/SCK/SCL
    Additionally, a fourth pin may be used when in a Slave
    mode of operation:
    • Slave Select (SS) RB5/SS/TX/CK
    When initializing the SPI, several options need to be
    specified. This is done by programming the appropriate
    control bits in the SSPCON register (SSPCON<5:0>)
    and the SSPSTAT register (SSPSTAT<7:6>). These
    control bits allow the following to be specified:
    • Master mode (SCK is the clock output)
    • Slave mode (SCK is the clock input)
    • Clock Polarity (IDLE state of SCK)
    • Clock Edge (output data on rising/falling
    edge of SCK)
    • Clock Rate (Master mode only)
    • Slave Select mode (Slave mode only)
    Question : I didn't see any Serial command in your example ?
    about the speed ? where to set it ?
    like all command .. just play with the SSP register bits ?
    may I use it like it is to "try something" mostly send commands
    to my friend's unit ..
    thanks in advance for your help
    Francois
    May 2007
    Smile SPI Interfacing
    Hi Francois,
    I will try to answer your questions.
    There are three examples of communicating with SPI devices. Each begins with a comment describing the device they apply to. After setting the value of two or three Bytes (valuebyte, commandbyte, and secondbyte), a GOSUB is called to move the data. The subroutines are: "sendspi" used to send commands to the digital pot and the amplifier and and "txrxspi" to command an ADC to convert and read back the data. The result of the data read back is put into the variable vcount. I know this does not look like much code but it is all you have to do. Simple, isn't it!?!
    Bits 3 - 0 of the SSPCON register select transmission speed. It is a function of the MCPU clock. In my instance, I use a 20 MHz oscillator and define at the top of my code using the define: DEFINE OSC 20.
    >>may I use it like it is to "try something" mostly send commands to my friend's unit
    Feel free to use this any way you wish. Note that the Byte values developed are for specific devices so you will have to adapt them to do your task and create a loop for them to run in.
    I hope I have explained adequately.
    Cheers,
    Mike
    Sep 2003
    INDIA
    Default Thanks Mike
    Hey Mike,
    Thanks for that explaination. Surely a lot of people will gain from it.
    regards
    Charudatt
    Nov 2007
    Default SPI to 7seg.
    I've tried to drive a 2 digits 8" tall 7segment using 74HC595 shift register with no luck ...any code snippets or reference? btw I'm using F88..
    Hi and welcome on the forum,
    did you tried with Shiftin/Shiftout or with the MSSP module?
    please, when you post a question, give us all details you have such as your code, schematic, compiler version, device programmer, etc etc.
    brighton
    See SPI clk speed adjustment post #13.
    First run program with Shiftin and Shiftout.
    Norm
  1. Using SPI with External Interrupts
    By shaiqbashir in forum mel PIC BASIC Pro
    Last Post: - 29th June 2008, 04:08
  2. 16-bit SPI problem
    Last Post: - 19th June 2008, 15:42
  3. SPI configuration PIC versus Atmel
    By Pedro Santos in forum mel PIC BASIC Pro
    Last Post: - 10th July 2007, 19:17
  4. How to configure SPI in PICBASIC PRO?
    By moogle in forum mel PIC BASIC Pro
    Last Post: - 15th April 2007, 18:31
  5. interfacing SPI with 2 pins?
    By modifyit in forum mel PIC BASIC Pro
    Last Post: - 1st December 2005, 22:04
