Model Rocket Launcher Help
Results 1 to 9 of 9
    Feb 2007
    I would place a turn key safty switch in line to make sure.
    Tim
    Mentor, Ohio
    Smile
    Hi Manuel,
    You should check the nuts & volts website as a model rocket launcher was a PIC project I believe early in 2006.
    I was looking into building a couple for my grandsons that was fully automatic with an ISD chip providing the countdown over a loud speaker adding the various system checks. I thought of using a relay to prevent accidental ignition. Have it wired normally open until a specific point in the countdown then if the other safety checks were okay then the relay would be switched on enabling launch voltage ready for the count to reach zero.
    I was heavy into rocketry as a kid myself! Have fun.
    BobK
    Post Jiggling ports at power up...
    Hi, Manu
    It's a VERY common Pic issue : defining pin states at power up ...
    so, it's easy but relatively unknown ...
    1) Write your output intial state : PORTx = % 00110010 i.e.
    2) Select input or output : TRISx = % 11000001 i.e.
    yes ... so simple as this !!!
    Jun 2007
    Hi
    I agree with Acetronics
    also this PULL-DOWN will not help if the pin went high for low time ,
    this will help to keep your PIN pulled to the ground (NOT FLOOATING) in case the pin was setuped as input or AN .
    good luck
    Hangover, Germany
    Smile
    After any reset the Pins will be set as input - for you, they will be tristate!
    So, add the pull-down-resistor an write a good programm !
    Jan 2007
    Hi there. Thanks a lot for all your answers!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
    Its great to be able to ask for help and get it so quick!!!!
    I will use the pull-down resistor and be sure to configure the port to output low.
    Thanks a lot again! Great forum!
    Manuel
  1. Rocket Altimeter
    By murphy6 in forum mel PIC BASIC
    Last Post: - 29th January 2008, 14:07
  2. Model Train controller - revisited
    Last Post: - 8th May 2007, 10:40
  3. Replies: 10
    Last Post: - 14th April 2007, 05:34
  4. Replies: 6
    Last Post: - 21st November 2006, 22:55
  5. PIC Model Numbers?
    Last Post: - 3rd January 2006, 03:31
