Better processing of a serial bitstream
Results 1 to 3 of 3
Threaded View
    Jun 2006
    Default Better processing of a serial bitstream
    I have a little side task that I have been working on, basically its a string of RGB led's strung together to produce a decorative christmas lighting effect.. Each of the LED's is actually a tiny PCB with a PIC12F629 on board which PWM each colour. These chips run at 4 MHz using their internal RC oscillator, and do not have inbuilt USARTs, using debugin we can achieve a maximum of 9600 baud.
    To address each PIC, a common serial line is fed to each of the PIC's and each PIC takes three bytes (one for each colour) out of the byte stream based on its ID (location in the chain). In addition there are two leading bytes of which we don't care about their value, they are merely used to trigger into the interrupt and a trailing byte. To prevent re-entry into the interrupt once we have received our LED values we wait until the sentinel byte is received.
    By now your probably starting to see the problem, with 25 PICs we have a string length of 75 + 3 bytes, at 9600 baud this will take somewhere in the region of 80ms per update. During this time the lights are out, and a noticeable flicker is observed. I have considered disabling the interrupt and using a timer to re-enable it later allowing the main PWM loop to continue. However this only fixes the problem near the beginning of the string. Towards the end we are still waiting ~80ms for the data to arrive. Another alternative is to address each PIC individually however this is quite inefficient when changing the entire string at once. Theres always using a chip with PWM or a separate PWM chip, but I already have the PIC's and PCBs, and besides on longer strings the fewer and cheaper the parts the better, currently it is only a PIC, RGB LED and 1uF cap per board. So the question I pose is, is there a better solution that I am missing to spend the least time away from the main loop yet still be able to address all PIC's and update them several times a second?
    I guess if I ever make another string I could use the PIC12F615 with an 8 MHz oscillator, but the fundamental problem still exists.
    My current code is below:
    @        __config _INTRC_OSC_NOCLKOUT & _WDT_OFF & _MCLRE_OFF & _CP_OFF
    DEFINE OSCCAL_1K 1
    DEFINE DEBUGIN_REG GPIO		' Set Debugin pin port
    DEFINE DEBUGIN_BIT 2		' Set Debugin pin bit
    DEFINE DEBUG_BAUD 9600		' Set Debugin baud rate (same as Debug baud)
    DEFINE DEBUGIN_MODE	0		' Set Debugin mode: 0 = true, 1 = inverted
    ID CON 1
    vRed				var Byte
    vBlue				var Byte
    vGreen				var Byte
    Buffer				var Byte
    Junk				var Byte
    Counter				var Byte
    Shaddow				var Byte
    'Symbols
    Symbol GIE			= INTCON.7		' Global Interrupt Enable
    Symbol PEIE			= INTCON.6		' Peripheral Interrupts Enabled
    Symbol INTIF 		= INTCON.1		' Ext Interrupt Flag
    Symbol INTIE		= INTCON.4		' Ext Interrupt Enable
    Symbol INTEDG		= OPTION_REG.6	' Interrupt Edge
    Symbol TMR1ON		= T1CON.0		' Timer1 On
    Symbol TMR1IE		= PIE1.0		' Timer1 Interrupt Enable
    Symbol TMR1IF		= PIR1.0		' Timer1 Interrupt Flag
    ' -------------- Pin Assignments --------------
    GP0					var GPIO.0
    gRed				var GPIO.1
    Rx					var GPIO.2
    GP3					var GPIO.3
    gGreen				var GPIO.4
    gBlue				var GPIO.5
    Symbol Red			= Shaddow.1
    Symbol Green		= Shaddow.4
    Symbol Blue			= Shaddow.5
    ' -------------- Initialisation --------------
    Initialisation:
    	'OSCCAL = %11111111 		' 4 MHz Internal Oscillator
       	Pause 50					' Safe Start Up Delay
    	ANSEL = %00000000			' Disable Analogue Inputs
    	CMCON = %00000000			' Disable Comparator
    	TRISIO = %00111111
    	Shaddow = %11111111
    	GPIO = Shaddow
    	Junk = 2 + 3 * (ID - 1)
    	vRed = 0
    	vGreen = 0
    	vBlue = 0
    	Input Rx
    	Output gRed
    	High gRed
    	Output gGreen
    	High gGreen
    	Output gBlue
    	High gBlue
    	'Enable Interrupts
    	GIE = 1
    	PEIE = 1
    	INTEDG = 0
    	INTIE = 1
    	INTIF = 0
    	ON INTERRUPT GOTO Int_Handle
    '-------------- Main Loop --------------
    Iterate:
    	DISABLE
    	If Counter = 0 Then Shaddow = %11001101
    	If Counter = vRed Then Red = 1
    	If Counter = vGreen Then Green = 1
    	If Counter = vBlue Then Blue = 1
    	GPIO = Shaddow
    	Counter = Counter + 1
    	ENABLE
    	Goto Iterate
    DISABLE
    ' -------------- Interrupts --------------
    Int_Handle:
    		GPIO = %11111111
    		DebugIn 1, Int_Exit, [skip Junk, vRed, vGreen, vBlue, wait (255)]
    		vRed = vRed
    		vGreen = vGreen
    		vBlue = vBlue
    		Counter = 0
    Int_Exit:
    	INTIF = 0
    	Resume
    ENABLE
    All the Best,
    Daniel
  1. Replies: 33
    Last Post: - 19th March 2010, 03:02
  2. Dynamic USB Serial Number (PIC18F4550)
    Last Post: - 16th July 2009, 17:03
  3. PIC18F4680 to PC via MAX232 (RS232 serial) no output
    By opticsteam1 in forum mel PIC BASIC Pro
    Last Post: - 14th April 2008, 20:39
  4. interfacing to the pc serial port
    By kelangfei in forum General
    Last Post: - 7th October 2007, 22:35
  5. Replies: 2
    Last Post: - 23rd July 2006, 08:16
