Have basically the same types of things on the aircraft. Gyro motors are 3 phase motors, but they'll run on 2 phases as long as you don't lose the common ground. Got an emergency inverter for a backup system. Takes DC and outputs 2 phases and a ground. I have a heck of a time trying to explain to the younger guys why the emergency inverter isn't designed to start the gyro motors (even though that's how the pilots check out the inverter and end up burning them up occassionally), it's only designed to keep them running in the event of a power failure.
About the 1 vs. 2 vs. 3 phase thing...I get that too. A lot of people seem to think they've got 3 phase power because they've got 220 hooked up to a dryer. I let them think that 'cause you just can't explain things to people who won't listen.
