1st time COMPARATOR use...
Results 1 to 8 of 8
    SWITZERLAND (french speaking)
    Hi Darrel,
    My battery delivers 9V so according to your post, the VRCON setting should be correct.
    I'm going to try the "110" Comparator mode; this, the functionality you explain, is exactly what I would like it to do.
    Darrel, would you know a tutorial about the use of Comparator? I'm getting lost more and more...
    Thank you.
    NB: every day, I play a full life; (SWItzerland - green circle - see attached map)
    Roger
    Yup, big difference between Sweden and switzerland. Doh!
    Not really, but maybe this will help. From Microchip...
    PICmicro Comparator Tips n Tricks
    http://ww1.microchip.com/downloads/e...Doc/41215a.pdf
    Or, it might just confuse things even more
    I've looked that statement over several times, and I'm still not sure what you meant.
    Your original VRCON should be correct?
    -- or--
    The VRCON according to my post should be correct?
    So, in case there's still some confusion, here's something that might help to understand the voltage divider part.
    It's already set up with your divider and 6.5v input...
    PIC Voltage Divider Calculator
    http://www.pbpgroup.com/modules/wfse...5&15,22000,6.5
    regards,
    Feb 2003
    Salt Lake City, Utah USA
    Smile
    See Melanie's post here
    http://list.picbasic.com/forum/messages/3064/3607.html?
    Paul Borgmeier
    Salt Lake City, UT
    USA
    __________________
    Default Even more basics...
    Yes Paul, I read Melanie's tutorial. At my level of comprehension, it is more like an example using a Comparator module in a 16F628.
    Yes Darrel, I read the MICROCHIP's Comparator Tips & Tricks document.
    The problem is, I don't clearly understand all the different pin/port/register names described in the datasheet. If some of them are obvious to me (VRef, A, D, etc..), others are not (CINV, VIN, CIN, etc..).
    Sorry if this sounds stupid and looked easy as a conventional ampli-op before I started, but all the µC-specific terminology messes my mind up.
    Just an example; when I read the 12F765's datasheet Comparator Operating Modes, I get lost at the very first figure....
    <img src="http://www.picbasic.co.uk/forum/attachment.php?attachmentid=1703&stc=1&d=118095092 1">
    Here, I assume I have to set ports GPIO.0 & GPIO.1 to Analog (ANSEL register); is this right? But what is with the Output? Is it going to turn to an "1" when CIN+ > CIN-? How will I use it?
    And now, is it just the same as before but when the condition is CIN+ > CIN-, does COUT (bit) go to a "1"?
    <img src="http://www.picbasic.co.uk/forum/attachment.php?attachmentid=1704&stc=1&d=118095155 5">
    What are CINV, VIN, CIN and what are they doing exactly?
    It's confusing me.
    Roger
    Default Got it working!
    Okay, after some more trials and a correct connection to GP1 (... not GP0!!!), I got it working.
    BUT how do I improve the accuracy?
    When the measured voltage ist between 2,3V and 2,6V, my led flickers.
    How do I fix this?
    Another strange thing: if I "forget" to set the GP1 input as Analog (ANSEL), it still works(!?).
    BTW, here are my corrected schema and code:
    <img src="http://www.picbasic.co.uk/forum/attachment.php?attachmentid=1708&stc=1&d=118097654 5">
    ' Fuses
    @ DEVICE PIC12F675,INTRC_OSC_NOCLKOUT ;Internal oscillator 4MHz
    @ DEVICE PIC12F675,WDT_OFF
    @ DEVICE PIC12F675,PWRT_ON
    @ DEVICE PIC12F675,MCLR_OFF
    @ DEVICE PIC12F675,BOD_OFF
    @ DEVICE PIC12F675,PROTECT_OFF
    @ DEVICE PIC12F675,CPD_OFF
    ' Registers    76543210
    OSCCAL      = %10000000 'Center frequency - used with Internal 4MHz OSC
    TRISIO      = %00000010 'Set Input/Output
    GPIO        = %00000000 'Ports High/Low
    WPU         = %00000000 'Weak pull-ups (check OPTION_REG)
    OPTION_REG  = %10000000 'Pull-ups / Interrupt / Prescaler
    ANSEL       = %00000010 'Analog I/O
    CMCON       = %01000100 'Comparator Module settings
    VRCON       = %10101100 'Voltage reference (= 2.5V)
    ' Variables
    BatVal   var CMCON.6
    BatLoLED var GPIO.2
    ' Program
    Pause 1 'Delay to allow for VREF to settle
    MAIN:
        BatLoLED = BatVal
        pause 10
        Goto Main
    Roger
  1. I don't understand this code!
    Last Post: - 13th February 2008, 02:55
  2. Measuring time
    By AugustoPedrone in forum mel PIC BASIC Pro
    Last Post: - 30th July 2007, 23:46
  3. Serout2/serin2 Pbp Problem
    By SOMRU in forum mel PIC BASIC Pro
    Last Post: - 11th December 2006, 19:55
  4. Alarm Time
    By Santana in forum Code Examples
    Last Post: - 8th December 2006, 13:58
  5. Timer in real time
    By martarse in forum mel PIC BASIC Pro
    Last Post: - 29th July 2005, 14:24
