Picbasic Bootloader ?
Results 1 to 10 of 10
    Mar 2006
    China
    Default Sure
    Since you never want to enter the bootloader with a jump from the reset vector (which is the normal way) you dont even have to add define loader_used 1 or what ever it should be.
    You just need to write the bootloader and program it to the high memory. Then you need to set the ICD2 to only program a certain momory area and then you can write your software as the bootloader didnt exist. This will over write the reset vector but in your case that is a good thing :-) Just make sure you dont write or erase the area where the bootloader lives.
    Then with a jump to your address for the loader you are ready to go. This is similar to the way I program some of my pics, from a 64k ee-card with the difference I only do it at startup or never at all.
    GPRS flashing seems to be a fun idea, that is why we like to write our own loaders!
    An other way is to program the loader, e-mail the applicationsoftware (since the PIC is blank you will end up in the loader anyway. Bootload the PIC and when it is all finished read out the hexfile with the ICD2 and use that 2-in-1 hex file for all the other 2 million pics or so in your production line.
    Hope I was clear....
    /me
    Italy
    Thank you Jumper,
    yes it's more than clear !
    Really I've tryed that way and it didn't work , but sure I did something of wrong, I'll try again.
    Many txs
    Marco
    Dec 2005
    I don't know whether this will help but there is a mikroBasic project for a UDP bootloader (using the ENC28J60) and 18F PICs.
    Perhaps this may help.
    http://www.oshonsoft.com/picbootloader.html
    regards
    Victor
  1. PIC18F4680 bootloader
    By vinyl_theif in forum General
    Last Post: - 29th January 2009, 18:45
  2. 18F4550 Bootloader enter via eeprom setting
    By bradb in forum mel PIC BASIC Pro
    Last Post: - 23rd November 2008, 00:51
  3. USBDemo with Bootloader
    By vacpress in forum USB
    Last Post: - 25th January 2007, 23:29
  4. Bootloader Problems
    By rossfree in forum mel PIC BASIC Pro
    Last Post: - 11th February 2005, 18:51
  5. PicBasic Fundamentals
    By Billyc in forum General
    Last Post: - 4th May 2004, 11:04
