PIC18F2320 RA4 output problem
Results 1 to 3 of 3
    May 2007
    Default PIC18F2320 RA4 output problem
    Hi!
    I'm using PIC18F2320 chip. It's needed to use PORTA.4 as digital output. Somehow with this program it doesn't give high value into PORTA.4 pin. PORTC.1 output is working. Are there any settings missing? From datasheet can't find any clue. With PIC18F2420 this program is working.
    p var PORTA.4
    k var PORTC.1
    CVRCON = 0
    CMCON = 7
    TRISA = %00000000
    TRISC = %00000000
    p = 1
    k = 1
    Talking Datasheet !!!
    Generally, RA.4 is an open collector as output pin ...
    need to be checked ... but 100% sure !!!
    May 2007
    Yup. There is open drain. So I changed the outputs a bit. Tnx.
  1. problem with input and output (18F452)
    By turkuaz in forum mel PIC BASIC Pro
    Last Post: - 18th March 2008, 00:21
  2. Serious Serial Situation Setbacks...
  3. problem with output RA2 and RA3
    Last Post: - 8th December 2006, 14:49
  4. HSEROUT No Output Problem
    By CocaColaKid in forum mel PIC BASIC Pro
    Last Post: - 22nd August 2005, 18:19
  5. Interrupt?? problem
    By scorpion in forum mel PIC BASIC Pro
    Last Post: - 15th July 2005, 05:14
