Reading Inputs
Results 1 to 4 of 4
Thread: Reading Inputs
    May 2007
    Suffolk, UK
    Default Reading Inputs
    I would appreciate some help/advice with what seems a very simple problem, however I am just starting out in this branch of the hobby and I’m a raw beginner with buckets to learn!
    I wish to read the lower 5 bits of my PIC (16F628) which are connected to 5 simple (0 or 1) sensors and then deliver a conditional result to a PORTA pin with IF…THEN statements. As an example IF PORTB = %11100100 THEN etc etc. This seems OK but I would like to remove the upper 3 bits as they are not required. I can hold these three pins high, for example, so they are always a 1 but it would be nice to ‘isolate’ them out of the logic. Is there a way of doing this, please? I hope that’s clear but effectively I would like to end up with a statement which simply says, for example IF PORTB (or MyVar) = 00100 THEN etc etc
    How to do this, please
    Many thanks
    Adrian
    Feb 2003
    Salt Lake City, Utah USA
    Smile
    Welcome
    What you want is to mask the top three bits
    MyVar=PORTB & %00011111
    IF MyVar = %00000100 THEN
    EDIT: See section 4.17.4 of the manual
    Last edited by paul borgmeier; - 29th May 2007 at 14:42. Reason: added manual reference
    Paul Borgmeier
    Salt Lake City, UT
    USA
    __________________
    yup,
    for reference about bit masking you could have a look at those
    http://en.wikipedia.org/wiki/Bitwise_operation
    http://en.wikipedia.org/wiki/Mask_(computing)
    Welcome here, and enjoy!
    May 2007
    Suffolk, UK
    Default Reading inputs
    Thank you both for excellent information. Lots to learn but absorption rate very high at present!!!
    Adrian
  1. Erratic analog inputs .
    By timseven in forum mel PIC BASIC Pro
    Last Post: - 10th October 2009, 23:34
  2. Unable to get 2 inputs to work
    By rangerdoc in forum mel PIC BASIC Pro
    Last Post: - 1st June 2008, 04:16
  3. inputs on 12F675 (or for that matter any PIC)
    By muddy0409 in forum mel PIC BASIC Pro
    Last Post: - 11th April 2007, 20:43
  4. Pot reading jumping like crazy!!!
    By champion in forum mel PIC BASIC Pro
    Last Post: - 20th November 2006, 22:24
  5. Using portb as inputs PIC goes crazy
    By peterdeco1 in forum mel PIC BASIC Pro
    Last Post: - 14th November 2005, 15:15
