Serial Wireless
Results 1 to 5 of 5
Thread: Serial Wireless
    Default Serial Wireless
    I know there is a simple solution for this, but I can not find it.
    I have two 16F676 both running on external 4Mhz oscillators. A TXM-433-LR-S and a RXM-433-LR-S.
    I know the RF is working as I can send a "HIGH" and receive a "HIGH" and blink a LED.
    I know the serial works, send a signal and blink a LED.
    Problem is when serial is sent with RF.
    I am using hyper-terminal to monitor the receiver. With wires I will see what I send and with out wires the first few characters will be garbage with the remaining correct.
    SERIN2 PORTC.4,16468,[WAIT("9"),DEC net]
    So I only want the last one.
    Send
    Asm
        ERRORLEVEL -306
        Endasm
    include "modedefs.bas"
    ANSEL=%00000000
    CMCON=7
    PAUSE 2000
    LOOP:
    IF PORTC.1 = 1 THEN
    SEROUT2 PORTC.4,16468,[DEC 01010101,DEC 9,DEC 3,10,13]
    HIGH PORTC.5
    PAUSE 100
    LOW PORTC.5
    PAUSE 100
    SEROUT2 PORTC.4,16468,[DEC 010101,DEC 9,DEC 5,10,13]
    PAUSE 200
    GOTO LOOP
    Receive
    DEFINE OSC 20
    Asm
        ERRORLEVEL -306
        Endasm
    ANSEL=%00000000
    CMCON=7
    net 	VAR WORD
    PAUSE 2000
    LOOP:
    IF net = 3 THEN
    HIGH PORTC.5
    PAUSE 100
    LOW PORTC.5
    PAUSE 100
    LOW PORTC.5
    PAUSE 200
    GOTO LOOP
    The last few characters are always the same with or with out wires on hyper-terminal.
    Why is the WAIT not working with RF.
    Tried different bauds, nothing.
    Tried different preambles, nothing.
    Send
    You're going to have problems with those two lines. DEC 01010101 will try to send out the number '1 million, 10 thousand, one hundred and one'. Use BIN 01010101 instead of DEC, or just make it easy and use '$55' instead. Also, instead of sending 'DEC 3' or 'DEC 5', just send '3' or '5' and change the receive code to match.
    Receive
    SERIN2 PORTC.4,16468,[WAIT(9),net]
    Try that change also and see what happens.
    Hi Skimask,
    Tried your suggestions. Works with wires but not RF.
    Read http://www.picbasic.co.uk/forum/show...light=wireless
    Tried sending $55 five times in a row, with the next line sending $66, or DEC 3,or 3. I know $66 is not 3, also changed receiver to match. All works with wires, Not with RF.
    Hyper-terminal shows that the data I want is there with wires of RF. The first "training" is garbled with RF but the last two or three characters are correct.
    PIC will not pick up the last character with RF.
    Repeating myself, over and over, hoping to see my blunder.
    Hyper-terminal is showing the training in one column and the data I want in another.
    Wires:
    UUUUU heart shape
    RF:
    TUU heart shape
    UU heart shape
    PUU heart shape
    @UU heart shape
    try serout...("UUUUU~~SYNCH",YourData)
    SERIN ...(WAIT("SYNCH"),YourData)
    don't forget Those UU are there only to balance the slicers, so not revealant to receive, ~~ here is just another character, You could still wait for only a part of SYNCH, let's say NCH.
    9600 could be a bit fast for testing, try 4800 or even 2400. When something work, you may need to increase and use some character pacing.
    For safety sake, on your transmitter, se the pin as output, clear it (=0) and add a few millisecond delay (~50) at the top of your code.
    In conjunction of a pull-down resistor on your receiver side as well.
    Thank you!!!!!!!!!!!!!!!!
    SERIN did the trick.
    Now I need to figure out why.
  1. Wireless serial communication question
    By Ahmadabuomar in forum Serial
    Last Post: - 21st December 2009, 04:49
  2. Dynamic USB Serial Number (PIC18F4550)
    Last Post: - 16th July 2009, 18:03
  3. PIC18F4680 to PC via MAX232 (RS232 serial) no output
    By opticsteam1 in forum mel PIC BASIC Pro
    Last Post: - 14th April 2008, 21:39
  4. interfacing to the pc serial port
    By kelangfei in forum General
    Last Post: - 7th October 2007, 23:35
  5. wireless serial data?
    By Scott in forum Serial
    Last Post: - 13th January 2006, 02:44
