' PICBASIC program to demonstrate operation of an LCD in 4-bit mode
Symbol PORTD = 8 ' PORTD is register 8
Symbol PORTE = 9 ' PORTD is register 9
Symbol TRISD = $88 ' PORTD data direction is register hexadecimal 88
Symbol TRISE = $89 ' PORTD data direction is register hexadecimal 89
Symbol ADCON1 = $9f ' ADCON1 is register hexadecimal 9f
Poke ADCON1, 7 ' Set analog pins to digital
Poke TRISD, 0 ' Set all PORTD lines to output
Poke TRISE, 0 ' Set all PORTE lines to output
Poke PORTE, 0 ' Start with enable low
Pause 100 ' Wait for LCD to power up
Gosub lcdinit ' Initialize the lcd
loop: Gosub lcdclr ' Clear lcd screen
For B4 = 0 To 4 ' Send string to lcd one letter at a time
Lookup B4, ("Hello"), B2 ' Get letter from string
Gosub lcddata ' Send letter in B2 to lcd
Next B4
Pause 500 ' Wait .5 second
Lookup B4, ("world"), B2 ' Get letter from string
Next B4
Goto loop ' Do it forever
' Subroutine to initialize the lcd - uses B2 and B3
lcdinit: Pause 15 ' Wait at least 15ms
Poke PORTD, $33 ' Initialize the lcd
Gosub lcdtog ' Toggle the lcd enable line
Pause 5 ' Wait at least 4.1ms
Pause 1 ' Wait at least 100us
Pause 1 ' Wait once more for good luck
Poke PORTD, $22 ' Put lcd into 4 bit mode
B2 = $28 ' 4 bit mode, 2 lines, 5x7 font
Gosub lcdcom ' Send B2 to lcd
B2 = $0c ' Lcd display on, no cursor, no blink
B2 = $06 ' Lcd entry mode set, increment, no shift
Goto lcdcom ' Exit through send lcd command
' Subroutine to clear the lcd screen - uses B2 and B3
lcdclr: B2 = 1 ' Set B2 to clear command and fall through to lcdcom
' Subroutine to send a command to the lcd - uses B2 and B3
lcdcom: Poke PORTE, 0 ' Set RS to command
lcdcd: B3 = B2 & $f0 ' Isolate top 4 bits
Poke PORTD, B3 ' Send upper 4 bits to lcd
B3 = B2 * 16 ' Shift botton 4 bits up to top 4 bits
Poke PORTD, B3 ' Send lower 4 bits to lcd
Pause 2 ' Wait 2ms for write to complete
' Subroutine to send data to the lcd - uses B2 and B3
lcddata: Poke PORTE, 1 ' Set RS to data
Goto lcdcd
' Subroutine to toggle the lcd enable line
lcdtog: Peek PORTE, B0 ' Get current PORTE value
B0 = B0 | %00000010 ' Set lcd enable line high
Poke PORTE, B0
B0 = B0 & %11111101 ' Set lcd enable line low
Poke PORTE, B0
