should be this one
http://www.melabs.com/resources/samples/x1/pbc/lcdx.bas
will check this latter today if someone didn't beat me to the punch... PBC is so WAY different of PBP. Too bad they don't have LCDOUT built-in![]()
should be this one
My guess is that you are sending a simple byte out to the LCD, and it is then displaying the ASCII equivalent. For example, take the following:
When Number1 is sent directly to the LCD, it will cause the “{“ to display.Code:Number1 VAR BYTE Number1 = 123
What you will need to do is enumerate each decimal place of the number and send that to the LCD. For example:
This will print out the leading "0"s, and will only enumerate a BYTE. It's just a simple code example, but it should help explain the concept and get you started on a more specific solution to met you needs.Code:Number1 VAR BYTE Temp VAR BYTE Number1 = 123 ‘Get Value of digit in 100’s place Temp = Number1/100 ‘With Number1 = 123 then Temp = 1 Temp = Temp + 48 ‘Convert value to ASCII equivalent ‘Send temp to LCD ‘Get Value of digit in 10’s place Temp = Number/10 ‘With Number1 = 123 then Temp = 12 Temp = Temp//10 ‘Get Remainder so with Number1 = 123 then Temp = 2 Temp = Temp + 48 ‘Convert value to ASCII equivalent ‘Send temp to LCD ‘Get Value of digit in 1’s place Temp = Number1//10 ‘Get Remainder so…with Number1 = 123 then Temp = 3 Temp = Temp + 48 ‘Convert value to ASCII equivalent ‘Send temp to LCD
Hope this helps, good luck.
SteveB
' PICBASIC program to demonstrate operation of an LCD in 4-bit mode
Symbol PORTD = 8 ' PORTD is register 8
Symbol PORTE = 9 ' PORTD is register 9
Symbol TRISD = $88 ' PORTD data direction is register hexadecimal 88
Symbol TRISE = $89 ' PORTD data direction is register hexadecimal 89
Symbol ADCON1 = $9f ' ADCON1 is register hexadecimal 9f
Poke ADCON1, 7 ' Set analog pins to digital
Poke TRISD, 0 ' Set all PORTD lines to output
Poke TRISE, 0 ' Set all PORTE lines to output
Poke PORTE, 0 ' Start with enable low
Pause 100 ' Wait for LCD to power up
Gosub lcdinit ' Initialize the lcd
loop: Gosub lcdclr ' Clear lcd screen
For B4 = 0 To 4 ' Send string to lcd one letter at a time
Lookup B4, ("Hello"), B2 ' Get letter from string
Gosub lcddata ' Send letter in B2 to lcd
Next B4
Pause 500 ' Wait .5 second
Lookup B4, ("world"), B2 ' Get letter from string
Next B4
Goto loop ' Do it forever
' Subroutine to initialize the lcd - uses B2 and B3
lcdinit: Pause 15 ' Wait at least 15ms
Poke PORTD, $33 ' Initialize the lcd
Gosub lcdtog ' Toggle the lcd enable line
Pause 5 ' Wait at least 4.1ms
Pause 1 ' Wait at least 100us
Pause 1 ' Wait once more for good luck
Poke PORTD, $22 ' Put lcd into 4 bit mode
B2 = $28 ' 4 bit mode, 2 lines, 5x7 font
Gosub lcdcom ' Send B2 to lcd
B2 = $0c ' Lcd display on, no cursor, no blink
B2 = $06 ' Lcd entry mode set, increment, no shift
Goto lcdcom ' Exit through send lcd command
' Subroutine to clear the lcd screen - uses B2 and B3
lcdclr: B2 = 1 ' Set B2 to clear command and fall through to lcdcom
' Subroutine to send a command to the lcd - uses B2 and B3
lcdcom: Poke PORTE, 0 ' Set RS to command
lcdcd: B3 = B2 & $f0 ' Isolate top 4 bits
Poke PORTD, B3 ' Send upper 4 bits to lcd
B3 = B2 * 16 ' Shift botton 4 bits up to top 4 bits
Poke PORTD, B3 ' Send lower 4 bits to lcd
Pause 2 ' Wait 2ms for write to complete
' Subroutine to send data to the lcd - uses B2 and B3
lcddata: Poke PORTE, 1 ' Set RS to data
Goto lcdcd
' Subroutine to toggle the lcd enable line
lcdtog: Peek PORTE, B0 ' Get current PORTE value
B0 = B0 | %00000010 ' Set lcd enable line high
Poke PORTE, B0
B0 = B0 & %11111101 ' Set lcd enable line low
Poke PORTE, B0
I am begning to think that I should get PBP. I seems alot more powerful.
Also I am tempted to look into the 'Lookup' and 'Lookdown' functions.
Thanks for the tips.
STeve
P.S. Thanks to Steve B.
That looks like something I can work with.
Yeah - like with the standard version of most things in this World, PIC Basic is only half of what you get in the PRO version. I throughly read between the lines before I made the decision to buy PBP, which at the time, almost twice the amount of the standard.
adding 48 to my number in the register worked great. I am still going to get the pro version. I hope there isnt too much of a learning curve from Picbasic.
I just purchased Pic Basic Pro because I heard alot of great things about it.
Again, Thanks for all the help.
Steve.
P.S. Just to let you know, Pics are often used in industry and it's good to mention on a resume if your going for any kind of technical job.
