Migrating PIC16F876a to PIC18F252
Results 1 to 5 of 5
    Jun 2007
    Default Migrating PIC16F876a to PIC18F252
    Using PicBasic Pro 2.43 I've migrated from a PIC16F876a to PIC18F252 to take advantage of additional code space.
    The PIC18F252 seems to always find the following statment to be TRUE regardless of the magnitudes of the values, i.e.:
    IF (frequency < threshold) THEN GoTo main
    Elsewhere, in my code, the variables "frequency" and "threshold" are functioning properly when manipulated mathmatically; however, the IF ( ) THEN statements are not fully reliable.
    Has anyone had experience such as this?
    Thank you,
    Jeff
    Quote Originally Posted by cohenjdc View Post
    Thank you,
    Jeff
    Nope, I've used PBP with the '452 (same basic thing) without a problem for years.
    Get the upgrade, $25/S&H @ MELabs.com
    T.Jackson's Avatar
    T.Jackson Guest
    Default Upgrade
    Suggest upgrading to the current version 2.47 ...
    <h4> A Glimpse at What Version 2.44 Offered / Corrected</h4>
    <ul>
    <li> Adds support for PIC16F54, 57, PIC18F2439, 2539, 4439, 4539, 6520, 6525, 6585, 6621, 6680, 8520, 8525, 8585, 8621 and 8680.</li>
    <li> Adds REPEAT..UNTIL.</li>
    <li> Adds 9 bit parity to HSERIN, HSERIN2, HSEROUT and HSEROUT2.</li>
    <li> Changes PIC18Fxxxx DATA and EEPROM to allow odd locations.</li>
    <li> Fixes constant folding for large numbers.</li>
    <li> Fixes unable to load COD file for MPLAB 6.</li>
    <li> Fixes parity with timeout in serial instructions.</li>
    <li> Fixes PIC18Xxxxx DEBUGIN modifier timeout.</li>
    <li> Fixes PIC18Xxxxx SERIN2 DEC modifier timeout.</li>
    <li> Fixes PIC18F1220 and 1320 configuration error.</li>
    <li> Fixes PIC18F6620, 6720, 8620 and 8720 BANK12 RAM setting.</li>
    </ul>
    Question PbP version involved ????
    Hi, Jeff
    I had such a behaviour and related it on this forum ...
    No help went ...
    but simply changing subs position cancelled the problem ( test was located in a sub, at the very end of the program !!! )
    PS: archive only keep 500 posts ... was written before !!!
    T.Jackson's Avatar
    T.Jackson Guest
    Post Could be a bug in PBP, don't ever close your mind to it.
    I personally have about 99% faith in PBP. No technology in this World is 100% reliable. While I've never actually discovered a bug in PBP myself, I have found a few in Visual Basic. Very strange - I wrote this rather lager program and, I had a variable named (LoopX) used extensively throughout with (For Nexts) Cut a long story short, in one procedure this variable refused to work. Always returning zero. It was globally declared as an integer. After many black cups of coffee and a lot of lost hair I decided to introduce a new variable into the scope of things, variable called (LoopZ) The procedure began to miraculously, flawlessly perform.
    Go figure ...:|
  1. Problem with ASM IRQ using FSR0 on PIC18F252
    By mytekcontrols in forum mel PIC BASIC Pro
    Last Post: - 11th March 2008, 20:48
  2. Runing a PIc16F876A
    Last Post: - 7th January 2007, 12:54
  3. pic18f252 hserout problem
    By edysan in forum Serial
    Last Post: - 16th June 2006, 20:46
  4. PLEASE HELP ME! pic16f876a and AD tlc4541
    By luca_sheva in forum mel PIC BASIC
    Last Post: - 1st February 2005, 17:32
  5. how to get PCF8574 and PIC16F876A work together
    By nomada in forum mel PIC BASIC Pro
    Last Post: - 15th December 2004, 02:07
