Led as a sensor ?
Results 1 to 3 of 3
Threaded View
    Default Led as a sensor ?
    Why is He using TMR0 in this code?
    '* Name : LedSensor.BAS *
    '* Author : Kifo *
    '* Notice : Copyright (c) 2004 kifo *
    '* : All Rights Reserved *
    '* Date : 15.01.2004 *
    '* Version : 1.0 *
    '* Notes : *
    LedAnoda VAR GPIO.0
    LedKatoda VAR GPIO.1
    GPIO = 0
    cmcon = 7 ' comparator (off , set as digital IO )
    TRISIO = %00000000 ' set GP 1,2,3,4,5 as outputs
    'WPU = %00110000 'pin gp3, gp4 - pull up enabled
    'option_reg.7 = 0 'global GPPU bit - za pull up enabled = 0
    'ANSEL = %00010001 'GP0 analog input , Fosc/8 ( A/D konverzija )
    'ADCON0 = %10000001 'chanel 0, stop AD, A/D On, Vdd = ref
    'ANSEL=0 'digital IO " samo za 12F675 "
    INTCON = %00000000 ' Onemoguci prekide
    INTCON.2 = 0 ' brisanje flega prekoracenja Tmr0
    option_reg = %10000111 ' timer 0 prescaler rate 1:256
    Low LedAnoda ' inverzni napon na led
    High LedKatoda ' led ne svijetli
    Input LedKatoda ' high Z na katodi led diode
    tmr0 = 0 ' reset timer 0
    WaitLow: IF TMR0 > 50 Then GoTo ukljuci ' tu određujemo razinu osvjetljenosti
    IF LedKatoda = 1 Then GoTo WaitLow ' čekamo kad padne nivo na nulu
    GoTo main ' ako ima dosta svjetla vraćamo se na main
    ukljuci: High LedAnoda ' ako nema dosta svjetla upalimo led diodu
    Low LedKatoda '
    Pause 400 ' led svjetli 400ms
    GoTo main
  1. Conway's Game Of Life
    Last Post: - 28th May 2020, 07:14
  2. Need a cheap touch sensor idea.. here it is
    By mister_e in forum Code Examples
    Last Post: - 16th April 2016, 23:42
  3. new and need help
    By smeghead in forum mel PIC BASIC Pro
    Last Post: - 3rd November 2008, 21:19
  4. LCD will not start
  5. can't even flash an LED
    By bruno333 in forum mel PIC BASIC Pro
    Last Post: - 28th April 2005, 14:27
