Thanks again guys for the time to help.
Steve:
Yep, the 628A is all I have ever bought. Never owned a 628"plain". I have a couple tubes full. I got out my reading glasses and looked to be *sure* Digikey didn't mess up, they did not.
re the ini fix thing, yes I tried that too just to be thorough, but other than selecting the chip, and having some MRU files listed, all was identical. It was a clean software install.
Darrel:
Can't use the on-board socket, chip is too long.
FWIW, the laptop dosen't have a printer built at all.
The desktop printer's port is a TCP/IP printer. The printer is brand new, installed last week. It does not even have a parallel port. Was odd to me too that it might be the culprit, but HP is not on my good guys list when it comes to loading bloatware on my PC.
OK, here's some fun.... I decided I'd try to figure out what was wrong with the desktop. I had some barcodes to print today (via LPT1) so figured it would be a good test to see of LPT1 was even functional (on the desktop). I disconnected my EPIC programmer fromthe cable and connected it to the parallel cable end already hanging off the bar code printer (2 25-pin cables now). Printed some labels, worked fine. A little while later, I unhook the cable and connect it back into the programmer on the desktop, poof, programs like it always did. Does it every time now. Something about printing through the prarllel port seems to have unhosed it. Before, it would not even read a chip, much less program it. A read erroneously said the chip was blank (it wasn't). Not so much as a reboot has happened since it wasn't working. ???
So I figure maybe a cold solder joint as Steve suggested or a hardware issue that has cleared. Reconnect the laptop, same behavior, programs spoatically, although it was taking fewer tries this time. Back to desktop, works OK still.
Oh well. As long as the desktop works. I'll ask Charles next week.
CHeers, Scott
