Button
Results 1 to 6 of 6
Thread: Button
    OK let's see if i understand your requirement.
    1. When ONLY PORTB.5 = 1 this should go to main
    2. if PORTB.5 = 1 and PORTB.7 = 1, this should write to the memory and after go to main.
    but you lost me with the pause 100... i may think you want to perform another operation if PORTB.1 have been hold more than 100 mSec... but not sure.
    Jun 2006
    I have two buttons . One to portb.5 and another to portb.7
    Yes ,when i press momentarily the button1 then go to main, and when i press button1 for a long time and when afterwards press button2, then write to the memory.
    Sorry fo my bad english.
    Don't worry about your English Savnik. I understand how hard it is to explain something when English is not your native language. I'm French... but Canadian
    OK let's see one method to do that... yeah the saturday pm one solution
            PORTB = 0
            TRISB=%10100000
            EEPROMWriteMode VAR PORTB.0
            WriteToEEPROM   var PORTB.1
            MainLed         var PORTB.2
            Delay var word
        MainLed = 1
        if PORTB.5 = 1 THEN GOSUB P_B_sub
    P_B_Sub:
        mainled = 0
        delay = 0
        while (PORTB.5 = 1) and (Delay<1000)
            pause 1
            delay=delay+1
            wend
        if delay<1000 then return
        eepromwritemode=1
        delay = 0
        while (PORTB.7 = 0) and (DELAY<1000)
            pause 1
            delay=delay+1
            wend
        if (delay<1000) then
            writetoeeprom =1
        eepromwritemode =0
        writetoeeprom = 0
    there's still the Timer Interrupt solution...
    Jun 2006
    Thank you.Your code help me to solve my problem.
    I use this code:
       	if PORTB.5 = 1 then
            while (PORTB.5 = 1) and (Delay < 1000)
                menu = 6
                pause 1
                delay = delay + 1
                wend
            if  delay < 1000 then
                delay = 0
                GOTO MAIN
                delay = 0
                WRITE W1, TMP_LO
    	        WRITE W1+1, TMP_HI
    	        LCDOUT $FE, 1, "     STORE    "
    	        PAUSE 1000
    	        menu = 2
    	        GOTO MAIN
    Good, enjoy!
    and mmm... παρακαλώ!
  1. Sony SIRC IR Issue
    By Ryan7777 in forum mel PIC BASIC Pro
    Last Post: - 8th August 2015, 08:10
  2. 3 HPWM channels
    Last Post: - 4th April 2006, 02:43
  3. Code check -- button not working
    Last Post: - 2nd March 2006, 22:43
  4. Button Push within 3 second Window
    Last Post: - 22nd December 2005, 10:06
  5. Button subfunction 16F628
    By Jųan in forum mel PIC BASIC Pro
    Last Post: - 19th August 2005, 16:44
