Pic Battery Charger
Results 1 to 8 of 8
    Oct 2003
    Australia
    Unhappy Pic Battery Charger
    I have a PIC circuit that flattens it's power source (9 volt battery) after a few days.
    I would like to modify the circuit so that if an external dc voltage source is connected (say 12 volts) the PIC will sence it and then start charging the nicad battery.
    Is it possible to have the pic charge it's own power source? What considerations should be made when charging a nicad?
    J
    This thread has been stuck in a posting queue until it got flagged today!
    If you have a 9v NiCad, and you plug in a 12v supply, then the PIC need not have anything to do with it. A simple Diode to block the 12v from directly connecting to the Battery with a Resistor across it to determine the charging current.
    Ni-cads are a little wimpish and don't like being mistreated (chose NiMH's for a more robust device). If the 12v Supply is likely to be left connected for any length of time (ie sevaral days), simply select a Resistor that will give you a trickle charge rate between say 5mA and 8mA.
    Tehran, Iran
    hi
    i want to produce a battery charger (using PIC16HV785) like that "rich DelRossi" worked on it: (its application note from Microchip)
    http://ww1.microchip.com/downloads/e...tes/01015a.pdf
    and i need its BASIC source file. its source file is in assembly language.
    can anyone help me?
    with best regards, Mostafa
    Jan 2006
    Toronto
    Would it be possible to take this one step further and produce a UPS?
    I have a bank of 4x 100A Deep Cycle Lead Acid batteries and 2x 3000W 12V DC to 120V AC invertors.
    I was hoping to put 2 batteries on each invertor and make some sort of charging system to go between the batteries and the invertors.
    I would like to put a PIC with either RS232, RS485, USB or even LAN in the charger to interface with a computer and an LCD to display the current power source (either AC or the Batteries) as well as how much power (either battery capacity or time) is remaining to allow for safe shutdown of the computers.
    I figured by using the AC invertors and a good 30A AC Power Supply might help make the project a bit easier. I would just have to make the interface between the power supply, batteries and invertor.
    Any help pointing me in the right direction would be greatly apreciated.
    Thanks.
    Boian's Avatar
    Boian Guest
    I want to build a Lead Acid Battery Charger with PIC16F785. I find that a "PS 200 Powrer Tools" from Microchip site conrol a schematic of charger of the Application Note.
    jeckjeck's Avatar
    jeckjeck Guest
    Default Re: Pic Battery Charger
    hi Squibcakes,could you solve this problem.because I have same problem with same project.
    Just so you know, Squib posted on 9th August 2004.
    Moved from Schematic.
  1. How can a battery powered PIC turn itself off?
    By tekart in forum mel PIC BASIC Pro
    Last Post: - 9th August 2012, 10:44
  2. Charger battery with pic12f675
    By Leonardo in forum mel PIC BASIC Pro
    Last Post: - 24th July 2009, 19:15
  3. Pic 16Fxx Battery Charger Help
    By wbjunkie in forum Schematics
    Last Post: - 15th December 2008, 19:34
  4. Serial Pic to Pic using HSER
  5. Battery Backup with PIC controlling switch
    By Dwayne in forum Schematics
    Last Post: - 27th December 2003, 13:16
