Microcode studio and USB pics
Results 1 to 8 of 8
    May 2007
    Red face Microcode studio and USB pics
    I want to program a 18f2550 (or any other pic ) which is supported by my ME labs programmer but is not in the drop down menu of microcode studio. I have been compiling programs in microcode studio under some other pic name and then switching to the 2550 for the programmer. This works for simple things, like an LED flasher but more specific commands like USB, the program will not compile under a different device name. In other words how do you use USB pics with microcode studio?
    Quote Originally Posted by KPDes View Post
    Download the latest version.
    May 2007
    I tried that before I made this post. I just tried it again and made sure it was the latest version ( 3.0.0.0) from the Mecanique web site and the usb pics still wont come up. Do you have to use Microcode Studio plus? Other than that I don’t know what I’m doing wrong.
    Thanks for the help
    -kyle
    Thanks for the help
    -kyle
    Which version of PBP do you have?
    May 2007
    PB pro 2.45
    PB pro 2.45
    You might notice here http://www.melabs.com/support/upgrade.htm that the '2550 isn't supported until 2.46.
    Spend the ~$25 and get an upgrade...
    There is a difference between compiling a program for a PIC and programming a PIC. In the former case you are creating a program (which is very much chip dependent) and in the latter you are attempting to place that chip dependent program into the correct chip.
    If, as I read into your posting, you are compiling a program for chip type A, and then trying to stuff that program into chip type B, then you are skating on thin ice. Indeed, I'm surprised that you've even managed to blink a LED like that and any kind of success would be pure chance.
    Always check this list... http://www.melabs.com/support/upgrade.htm
    If your version of PBP doesn't support the particular chip of your choice (and in your case version 2.45 doesn't support 18F2550) then it's not likely to work. Upgrade your product and it'll work properly as advertised.
    OK, skimask beats me to the salient comment!
  1. Pickit3 from Microcode Studio
    By Normnet in forum General
    Last Post: - 26th January 2014, 10:06
  2. Simple USB Comms Problem
    Last Post: - 6th January 2010, 21:17
  3. Microcode studio loader problem
    By woodygjw in forum General
    Last Post: - 10th September 2007, 02:18
  4. Speed of USB EasyHID and Time problem
    By sjohansson in forum USB
    Last Post: - 18th January 2007, 23:21
  5. Replies: 2
    Last Post: - 25th February 2006, 03:53
