Problems controlling multiple pics
Results 1 to 12 of 12
    May 2007
    Question Problems controlling multiple pics
    I am currently in the process of designing a servo controller. I have already been able to make a pic that can take a message from a pc serial port and command 11 servos position, and speed.
    Now I am having a very hard time taking the messages from a computer, and distributing them to multiple controllers.
    For now I am attempting to just control one servo controller, with one master pic interfaced to the pc.
    master pic
            define OSC 8
            OSCCON = %1111110 ' sets internal osc to run at 8MHZ
    '----------turn analog on porta off, and use as digital input/output '----------this is used to allow serial input on the A bus.
            CMCON = 7 'Comparators OFF
            ANSEL = 0 'A/D OFF -- Port pins all digital
    '---**Pins
    rsoutpin var porta.0
    rsinpin var porta.1
    picinpin var portb.4
    picoutpin var portb.5
    '---vars
        '-------- transfer vars
       message var byte
    '---main program
    gosub pcin
    gosub picout
    '----- retrieve next set of commands from pc.
    pcin:
    '----send serial request, and get user input, timeout 70 ms
            serout2 rsoutpin, 16468, ["ready set go!"] 'call for data
            serin2 rsinpin, 16468, 70, main, [message]
    '-----end serial request
    '---- picout procedure waits for high on picinpin and then transmits data
    picout:
    input picinpin
    '--- wait until pic is ready to recieve
    while picinpin = 0
    pause 1
    wend
    '-transmit message to pic.
    serout2 picoutpin, 16468, [donecommanding]
    slave pic
            define OSC 8
    '---**Pins
    picinpin var porta.1
    picoutpin var porta.0
    ledpin var portb.4
    '---**Variables
    '---processing vars
    ledstat var byte
    '------**main program
    gosub recieve
    gosub driveled
    goto main   'loop forever
    recieve:
    '----send ready signal and wait for message with timeout 150.
            high picoutpin  ' ready to recieve
            serin2 picinpin, 16468, 150, driveled,[ledstat]
            low picoutpin 'not ready to recieve data.
    return 'return to main routine
    driveled:
    if ledstat =  "O" then
    high  ledpin 'turn on led
    low ledpin 'turn off led
    Now this code actually works when I send "O" the light turns on, when I send something else it turns off.
    My problem is I have to be able to transfer data that looks like this "03|005|225|y".
    DEC2 servonumber "|" DEC3 rate "|" DEC3 position "|" finalcommand (single byte "y"/"n")
    I have been unable to transmit this kind of data, and in addition to that I will need to have the master look at the servonumber and send the message to the appropriate slave with the correct servonumber (as all the slaves will be numbered the same internally)
    Please let me know if you have any suggestions, or insight into how to achieve this. I have made multiple attempts, but apparently my brain is not working.
    Different method to do that, i'll suggest to have a look at the following link
    How to make your own PIC network
    http://www.picbasic.co.uk/forum/showthread.php?t=1192
    This could give you some pointers.
    HTH
    PS: most here, including myself, don't recommend to use the internal OSC for serial communication for reliability reasons. If your PIC have a USART, you should use it. HSERIN/HSEROUT. I'll also suggest you to read the available Modifier list. WAIT will be handy in your case.
    May 2007
    Default hserin/hserout
    I am using 16f88 which does have an internal AUSART. But what is the difference between serin2 and hserin. I am a little confused about it.
    Aug 2005
    NC
    Default Serin2 & HSERIN
    Serin2 & HSerin share modifiers you can use, but to use HSerin you must set the config bits in the PIC to specify you are using a hardware communication option instead of "bit banging" the serial comms using Serin2 (or Serin, for that matter).
    Sorry, but you'll have to spend some more time in both the manual and the datasheet for your PIC to get it set up properly. Do a search in the Archives here in the forum, and with Google if you need more help. I've just about finished getting my comms working as I need, using these same procedures.
    Good luck!
    Brad
    Quote Originally Posted by gandora View Post
    HSEROUT or HSERIN use the PIC Hardware USART, while SERIN/SERIN2/DEBUGIN use a software Serial communication solution.
    The only restriction when you're using HSERIN/HSEROUT is the I/O and the amount of serial port. With HSERIN/HSEROUT, you MUST use the PIC dedicated i/o (RX/TX) while any other software solution (SERIN.. ) allow you to choose any i/o.
    Using the PIC USART give you for free at very least, a 2 Bytes receiver buffer, and interrupt trigger sources.
    May 2007
    Post I got it working
    Now thankyou all for your feedback, I still don't know exactly how to use hserin yet, but I will most certainly use it later. However I was able to come up with a way of getting my method to work.
    Now the biggest problem is that using the internal clocks on both the master and the slave makes errors pop up, but I came up with a way to check for errors and continue to retransmit, or request data until it is error free. And I came up with the solution to the original problem which was that I just needed to use STR message\12. What I was doing in the original code was converting multiple bytes into single bytes, and then attempting to transfer them in that form, which changed the data format causing it to be unreadable by the driver.
    the simplest method to solve that problem is:
    message VAR byte[12]
    serin2 pcinpin, 16468, [STR message\12]
    and then
    serout2 picoutpin, 16468, [STR message\12]
    the problem with the above code is the fact that during the process of recieving and transmitting twice its almost guarenteed you will get bad data at some point.
    my solution :master code:
            define OSC 8
    '---**Pins
    rsinpin var porta.1
    porta=0
    portb=0
    '---vars
        'servonum var byte: rate var word:position var word:donecommanding var byte
     message  var byte[12]
     message2  var byte[12]
    '---main program
    goto pcin
    pcin:
            serout2 rsoutpin, 16468, ["waiting!"] 'call for data
            serin2 rsinpin, 16468, [str message\12,str message2\12]
    'compare both arrays
        if message[0]=message2[0] and message[1]=message2[1] and _
        message[2]=message2[2] and message[3]=message2[3] and _
        message[4]=message2[4] and message[5]=message2[5] and _
        message[6]=message2[6] and message[7]=message2[7] and _
        message[8]=message2[8] and message[9]=message2[9] and _
        message[10]=message2[10] and message[11]=message2[11] then
            'arrays equal eachother then
            serout2 rsoutpin, 16468, [str message\12]
            goto picout
    serout2 rsoutpin, 16468, ["bad data!"]
    goto pcin
    picout:
        input picinpin
            while picinpin = 0
            pause 1
            wend
        serout2 picoutpin, 16468, [str message\12,str message\12]
        pause 6
            if picinpin = 1 then      'checks if data was recieved
            goto picout  're-send until recieved
    serout2 rsoutpin, 16468, ["|transmission succesful|"] 'tell computer
    goto pcin
    Here is the code for the slaves recieve portion:
    recieve:
    '----send high pic request, and get user input for motor drive
             high picoutpin
            '--by using skip 1 rather then wait ("|") losing data is
            '--prevented when wait is used if the data goes through
            '--wrong the command is lost altogether.
            serin2 picinpin, 16468,15,drivemotor, [dec2 servonum,skip 1,_
            dec3 rate,skip 1,dec3 position,skip 1,donecommanding,_
            dec2 servonum2,skip 1,dec3 rate2,skip 1,dec3 position2,skip 1,_
            donecommanding2]
            '---verify that the data matches
            if servonum!=servonum2 or rate!=rate2 or position!=position2 or _
            donecommanding!=donecommanding2 then
            'data is bad recieve again
            goto recieve 'try again
            low picoutpin
    gosub setupservo
    goto drivemotor 'return to main routine
    I have one question, would using a lower baud rate decrease the frequency of errors? If you have any suggestions to improve this code, please feel free to through in your two cents. Thanks again!
    Now the biggest problem is that using the internal clocks on both the master and the slave makes errors pop up.........
    You aren't going to be able to get away from serial transmission/reception errors when using the internal oscillator. If you were using the hardware UART, you might be able to tweak the baud by using the overrun and framing error bits in the UART itself (overrun generally too slow baud, framing generally too fast baud rate). But overall, if you're not tweaking OSCTUN for each 'F88, it's a crapshoot as to whether or not you oscillator is running near it's spec'd frequency or not, thereby, your SERIAL commands are off by the same amount.
    And a lower baud rate might help, but it's certainly not a fix.
    'compare both arrays  -- easier to read method I think....
    for temp = 0 to 11 : if message[temp] <> message2[temp] then goto baddataout
    next temp
    serout2 rsoutpin, 16468, [str message\12]        'arrays equal each other
    goto picout
    baddataout:
    goto pcin
    May 2007
    Lightbulb Thankyou so much!
    Awesome coding suggestions. I was able to get rid of 4 pages of code using similar thinking after you showed me that. (guess my brain just finally started working) ^^
    also, I tried something just as a blind guess at a way to fix the problem, or help a little, and it worked really well. I put a 470 ohm resistor to the ground from the picin pin on the slave. seems to have gotten rid of noise that was causing it to think it was recieving data when it wasn't, and it lowered the number of errors in general pretty significantly.
    Maybe thats standard practice? Or was it really insanity to genius. Anyways hopefully that fixed it. ^^
    Hmmmm, What it does is short out the hi impeadence noise, since the noise doesn't have the amperage to carry through, but the signal does.
    May 2007
    Thumbs up
    Thats what I thought it was doing, I did the same thing with the line in from the pc and I haven't had any errors since, but I still have the double buffer system that will make sure i know when i get one.
    Now I can move on to the next challenge. Which is, having multiple commands qued to be executed at once.
    I will get to work on that task and post my results when I get somewhere with it.
  1. Multiple PICS from Same Crystal?
    By WOZZY-2010 in forum General
    Last Post: - 6th February 2010, 15:18
  2. Multiple Pics accessing single EEPROM
    By Atom058 in forum mel PIC BASIC Pro
    Last Post: - 3rd February 2008, 17:22
  3. Retrieving infos from multiple PICs on a bus/chain
    Last Post: - 15th October 2007, 04:42
  4. Multiple PIC's with 1 crystal
    By puma in forum Schematics
    Last Post: - 20th March 2007, 17:02
  5. Multiple Pics to One serial port
    By Rleonard in forum Serial
    Last Post: - 18th January 2007, 18:30
