3 phase sequencing
Results 1 to 15 of 15
    Default 3 phase sequencing
    Hi, here is the requirement;
    I need to monitor the 3 mains phases and detect if (a) one goes dead and (b) if the 3 phases are incorrectly sequenced. The 3 phases are being fed to 3 different pins on a 16F676.
    The first part seems relatively easy; the second one I'm struggling to find a solutioion for. Am I on the right track here?
    The following is for 50 hz;
    I plotted the 3 phase waveforms in Excel, to better visualize the timings, and here is what I feel.
    If the sequence is correct, the time between 2 corresponding points on adjacent phases would be 10.33 ms; this would be twice that if the wires are incorrectly sequenced.
    Now, what makes things complex is that I'd also like to serially be outputtng the 3 readings in a cycle. How can this be done best?
    I suspect the easiest solution lies in Darrel's 'Instant Interrupts' article, but I still dont quite get how the logic should be.
    Has anyone on the list done something similar?
    Thanks for any insight on this.
    Anand
    Sorry, that should have read 6.67 ms.
    Anand
    Off the top of my head...just an idea...may or may not work...
    Rectify and regulate each phase, use a zener diode on each phase to get each phase to output a 5v pulse.
    Input each phase's output pulse to RA0-1-2, use the 'Interrupt on Change' feature.
    Set up TMR1 with your oscillator speed (prescalers, etc) so you can get decent resolution and yet be able to count up to 10.33ms.
    Enable RA0/RA1/RA2 I/O/C. Wait for the leading edge of the RA0 pulse using the Interrupt. Save TMR1 value. Wait for the RA1 pulse, save that time. Wait for the RA2 pulse and while waiting, subtract the TMR1 values for the RA1 and RA0 pulses and make sure they're within spec.
    If, for instance, after you get the RA0 pulse, you get the RA2 pulse next, you know you've skipped the RA1 pulse and that phase is probably missing.
    I'm thinking of a sort of 'software latch', where one pulse enables getting another pulse, which in turn enables getting another pulse. If anything other than the pulse you are waiting for shows up, then flag an error. And in the meanwhile waiting for pulses, you do a bit of math to make sure the pulses are coming at the right times.
    Dec 2005
    Using Interrupt On Change you'll get an interrupt every 3.33mS. I think all you need to do is check the pin number and polarity of the interrupt (rising/falling) for the sequence and reset a timer set to overflow at ~3.5mS. If the timer overflows, you're missing a phase.
    Of course, you already know you can connect the phases through current limiting resistors as shown in Microchip's AN236.
    If you output A, B, or C for a rising edges and a, b or c for falling edges you should see ABCabcABCabc...
    I think RA does not have Interrupts.
    Anyway the idea is correct. Another add-on would be to have a learn stage, so the connections of the R-S-T can be memorized first, and then turn into running mode for continuous checking of the sequence.
    Hi Skimask, Dave,
    Thanks. Do I understand that both of you are essentially suggesting a similar thing?
    Dave, as you pointed out I have directly input the phases thru' resistors. This effectively gives me only 3 half cycles per 3-phase cycle. For what you suggest would I need to have full-wave rectified signals (6 half cycles) at the inputs?
    Sorry I'm being dense about this but its a first as far as 3 phase design is concerned.
    Anand
    T.Jackson's Avatar
    T.Jackson Guest
    Post
    I hope someone's a licensed electrician here - I'm all for the competent hobbyist playing around with single phase (110 -240), but 3 phase 415V being feed to a digital circuit, when I hear someone say "this a first for me", makes me wonder if it's really such a good idea.
    Dec 2005
    Anand, assuming you use pins capable of Interrupt on Change, you'll get an interrupt on both the rising and falling edge. It's the same as using it for ZC detection in AN236 which also discusses the slight assymetry because of different trigger voltages for rising vs. falling edges.
    Look at the second oscilloscope screenshot on this page. It's a ZC detector on pin 13 of the PIC.The protection diodes on the pin effectively give you a square wave. In your case, the higher voltage will give steeper edges. You'll get 100 interrupts per second per phase or 300 total per second.
    Interrupt on Change cannot be preset for falling or rising edges. It interrupts on both and sets register bits to indicate the pin and rising or falling. On each interrupt you reset the timer, check the register bits to determine pin & polarity, clear the interrupt and output your coded representation of the event.
    P.S. What I'm suggesting is much, much simpler than what Skimask suggested.
  1. 3 phase supply detector challenge
    By BobEdge in forum mel PIC BASIC Pro
    Last Post: - 15th May 2009, 07:54
  2. 3 phase PWM with dsPIC30F2020
    By nemmard in forum mel PIC BASIC
    Last Post: - 21st January 2009, 14:19
  3. Understanding 3 phase sequencing
    By ardhuru in forum General
    Last Post: - 22nd June 2008, 10:14
  4. Someone help me to simplify this
    By thrix in forum General
    Last Post: - 21st February 2004, 05:01
  5. Help wanted..
    By thrix in forum mel PIC BASIC Pro
    Last Post: - 17th February 2004, 23:44
