Big big big memory or tiny SDs!
Results 1 to 10 of 10
    May 2006
    Del Rio, TX, USA
    How about the Atmel DataFlash chips? They're gettin' big these days (big as in good capacity)
    I've also used the Atmel Dataflash (AT45DB321C (32MB)). Worked well with Shiftin/Shiftout. Also worked with the Hardware SPI, just a little harder to setup.
    The hardest part is finding a supplier with some in stock. I think I got some obsolete SOIC parts from Arrow, but it's been a while. Digi-key lists all of there compenents as Non-Stock, but you might give them a call.
    SteveB
    Sep 2003
    Vermont
    I found a supplier for the micro SD sockets. I was thinking of breaking out the old "FAT" code and installing it permanently on the board. For my proto, I will more than likely use the ST part. The down side to the SD card is the power consumption...but you can't beat the $15.- price!
    Thanks for the leads,
    Ron
    Quote Originally Posted by SteveB View Post
    SteveB
    I just checked Digikey. Searched for 'Atmel Dataflash' and clicked 'Items in Stock'. I get 42 results for parts in stock, ranging from 1Mbit up to 64Mbit parts.
    May 2006
    Del Rio, TX, USA
    Yep. I must have narrowed my previous search too much. 16Mb SOIC for $2.37.
    SteveB
  1. Need the code to write to a memory
    By Hamlet in forum General
    Last Post: - 20th August 2007, 01:22
  2. Replies: 4
    Last Post: - 2nd March 2007, 07:12
  3. Which pic has a big flash program memory?
    By amindzo in forum mel PIC BASIC Pro
    Last Post: - 1st November 2006, 20:35
