Big big big memory or tiny SDs!
Results 1 to 10 of 10
    No need for flash card, M25P16 will be more than enough. 16Mb and SPI. No need for extra annoying socket. small, cheap and reliable.
    http://www.st.com/stonline/books/pdf/docs/10027.pdf
    also W25P16VSFIG.
    http://www.winbond-usa.com/products/...P80-16-32j.pdf
    Both above are supported in my BKPrecision 844A.
    Never used them so far.
    Sep 2003
    Vermont
    Thanks Steve,
    I have a 1 MByte chip from ST, but I would really like some acreage! How about the memory inside the thumb drives?
    Thumb drive? USB ones? If so you should have a look to MAX3421E, this should do the trick. Nice reference http://www.ghielectronics.com/details.php?id=13
    Those are in stock here... never had any time to play with...
    SD card pinout
    http://pinouts.ru/Memory/sdcard_pinout.shtml
    Quote Originally Posted by Ron Marcus View Post
    Thanks Steve,
    How about the Atmel DataFlash chips? They're gettin' big these days (big as in good capacity)
    I played with this awhile back, converted it to PBP (which was a piece of cake). A bit on the slow side, could've had faster transfers had I used the SPI module on the PIC itself.
    http://www.emesystems.com/BS2flash.htm
    http://www.digikey.com/scripts/DkSea...463292&Site=US
    $2.37USD each at Digikey.
    May 2006
    Del Rio, TX, USA
    I've also used the Atmel Dataflash (AT45DB321C (32MB)). Worked well with Shiftin/Shiftout. Also worked with the Hardware SPI, just a little harder to setup.
    The hardest part is finding a supplier with some in stock. I think I got some obsolete SOIC parts from Arrow, but it's been a while. Digi-key lists all of there compenents as Non-Stock, but you might give them a call.
    SteveB
    Sep 2003
    Vermont
    I found a supplier for the micro SD sockets. I was thinking of breaking out the old "FAT" code and installing it permanently on the board. For my proto, I will more than likely use the ST part. The down side to the SD card is the power consumption...but you can't beat the $15.- price!
    Thanks for the leads,
    Ron
    Quote Originally Posted by SteveB View Post
    SteveB
    I just checked Digikey. Searched for 'Atmel Dataflash' and clicked 'Items in Stock'. I get 42 results for parts in stock, ranging from 1Mbit up to 64Mbit parts.
    May 2006
    Del Rio, TX, USA
    Yep. I must have narrowed my previous search too much. 16Mb SOIC for $2.37.
    SteveB
  1. Need the code to write to a memory
    By Hamlet in forum General
    Last Post: - 20th August 2007, 01:22
  2. Replies: 4
    Last Post: - 2nd March 2007, 07:12
  3. Which pic has a big flash program memory?
    By amindzo in forum mel PIC BASIC Pro
    Last Post: - 1st November 2006, 20:35
