Interfacing two PIC micros
Results 1 to 13 of 13
    May 2007
    Smile
    Thanks guys, for atleast replying to my query.
    Sorry, for that DIM thing....its my first post, remember that. (Thanks, mister_e )
    Im using Crownhill Proton, I wud ask them, about DIMming anything....
    OK......lets forget that. Now I want to do it in PBP. Can anybody help me in my queries, for interfacing two PICs, like,
    i) what should be the read/write address for the slave PIC
    ii) How can we define variables in a particular memory location (in slave PIC), using PBP
    iii) How to define SDA and SCL pins on the slave PIC.
    Thanks all for the response (good or bad), I appreciate that. Now, experts, please help me with this.
    Sajid
    Quote Originally Posted by sajid View Post
    It's whatever you program the slave PIC to respond to.
    PBP manual, Section 9.3, 'Interrupts in Assembler' has some good hints on how to set a specific variable to a specific location...but I wouldn't count on it. Easier (in my mind) to let PBP assign a location for you, then you program around it.
    You realize PBP only supports I2C master modes, not slave modes. The PIC itself, if so equipped, can use I2C in a slave mode, but you have to program that manually, PBP won't help much in that respect. There is a few web pages out there with good PIC I2C slave code, don't remember where they are, don't have them bookmarked, but I've seen them.
    I know that's not some sort of DEMAND...like somebody owe's you something. You'd be much more likely to get some help if YOU wrote some code YOURSELF and pointed out where YOU are having trouble.
    EDIT: Got this from a Google search for 'PIC I2C slave'
    http://www.astrosurf.com/soubie/pic_as_an_i2c_slave.htm
    1st link. Was that so hard?
    Last edited by skimask; - 25th May 2007 at 08:22. Reason: edit: added I2C slave link
    May 2007
    Smile
    Thanks, Skimask.
    Thanks, Steve.
    Skimask Sir, I am sorry about that 'expert' line. Since everyone took my query lightly, so I was bit frustrated. I sincerley apologize.
    The links and tips provided by you and Steve, are really helpful.
    I will certainly keep informing you all, as I work on it.
    Thanks to you all, again.
    Sajid
  1. TTL(i) or CMOS for interfacing to PIC?
    By Elnino in forum Off Topic
    Last Post: - 16th September 2009, 02:35
  2. Interfacing DS1603 to PIC 16F877
    By hackableFM in forum mel PIC BASIC Pro
    Last Post: - 25th February 2009, 22:37
  3. PLC Interfacing with PIC
    By skian85 in forum mel PIC BASIC Pro
    Last Post: - 20th June 2008, 00:05
  4. PIC interfacing with FTDI's VDIP1
    By Vidya in forum mel PIC BASIC Pro
    Last Post: - 12th May 2008, 18:02
