PIC lcd ds1820
Results 1 to 3 of 3
Thread: PIC lcd ds1820
    May 2007
    Default PIC lcd ds1820
    Hello!
    I starting programm this device.
    I have some code, but ds not working.
    Could someone check this?
    Define CONF_WORD = 0x3f72
    Define CLOCK_FREQUENCY = 6
    AllDigital
    Define LCD_BITS = 8
    Define LCD_DREG = PORTD
    Define LCD_DBIT = 0
    Define LCD_RSREG = PORTE
    Define LCD_RSBIT = 0
    Define LCD_RWREG = PORTE
    Define LCD_RWBIT = 1
    Define LCD_EREG = PORTE
    Define LCD_EBIT = 2
    Define LCD_READ_BUSY_FLAG = 1
    Define 1WIRE_REG = PORTA
    Define 1WIRE_BIT = 1
    Lcdinit
    Dim i As Byte
    Dim j1 As Byte
    Dim j2 As Byte
    Dim por1 As Byte
    Dim por2 As Byte
    Dim text As char
    text = "Temperature:"
    PORTB = 0 ' initialize PORTB to 0
    PORTA = 255 ' initialize PORTA to 255
    TRISB = 0 ' PORTB is output
    TRISA = 255 ' PORTA is input
    lcd_init(PORTB)
    lcd_cmd(lcd_cursor_off)
    lcd_out(1, 1, text)
    do
    ow_reset(PORTA, 5) ' 1-wire reset signal
    ow_write(PORTA, 5, $cc) ' issue command to DS1820
    ow_write(PORTA, 5, $44) ' issue command to DS1820
    delay_ms(120)
    i = ow_reset(PORTA, 5)
    ow_write(PORTA, 5, $be) ' issue command to DS1820
    delay_ms(1000)
    j1 = ow_read(PORTA, 5) ' get result
    j2 = ow_read(PORTA, 5) ' get result
    j1 = j1 > > 1 ' assuming the temp. >= 0C
    bytetostr(j1, text) ' convert j1 to text
    lcd_out(2, 8, text) ' print text
    lcd_chr(2, 10, 223) ' degree character (°)
    lcd_chr(2, 11, "C")
    delay_ms(500)
    loop until False ' endless loop
    End .
    skimask's Avatar
    skimask Guest
    Quote Originally Posted by wchpikus View Post
    Hello!
    That's Proton Basic. This is PicBasicPro.
    Proton Basic <> PicBasicPro.
    It's not Proton, looks more OshonSoft's PICBasic to me
    http://www.oshonsoft.com/pic.html
    Sorry, i can't help much
  1. Is this code not initialising the LCD properly?
    By Platypus in forum mel PIC BASIC Pro
    Last Post: - 30th January 2010, 20:14
    Last Post: - 8th August 2009, 20:54
  3. LCD Display not working - PIC heating...
    Last Post: - 24th September 2006, 08:35
  4. Serial Pic to Pic using HSER
    Last Post: - 12th March 2005, 00:14
  5. LCD 20X4 connect with DS1820
    By jojokatada in forum mel PIC BASIC Pro
    Last Post: - 9th March 2005, 12:04
