12F629 Strange interupt behavior
Results 1 to 9 of 9
    Fayetteville Arkansas
    Default 12F629 Strange interupt behavior
    Below is my code. What I dam doing is controlling a camera. Initially I have 1 button that sets a variable from 1 to 3. Under each variable I set certain functions. Under #1 I set delays between pictures, under #2 I set 24hour, day only, or night only pictures. Under #3 I set standard camera mode, double picture mode or video mode. GPIO.1 sets the 3 variables and GPIO.3 sets the stuff under each variable. An led blinks a corresponding number of times for these. GPIO.0 triggers the pic to take pictures.
    The problem I am having is in the routine that determines if it should take a picture if its day or night. In either case the led starts blinking and it increments the variables. If it is set to 24 hour it works fine. If someone could take a look and possibly see anything that would cause this I'd appreciate it. I've about pulled all my hair out. BTW, some labeling is wrong, ignore it.
    @ DEVICE pic12F629, INTRC_OSC_NOCLKOUT ; System Clock Options
    @ DEVICE pic12F629, WDT_ON ; Watchdog Timer
    @ DEVICE pic12F629, PWRT_ON ; Power-On Timer
    @ DEVICE pic12F629, MCLR_OFF ; Master Clear Options (Internal)
    @ DEVICE pic12F629, BOD_OFF ; Brown-Out Detect
    @ DEVICE pic12F629, CPD_ON ; Data Memory Code Protect
    @ DEVICE pic12F629, PROTECT_OFF
    ; Set Variables and aliases as needed.
    symbol TRIG = GPIO.0
    SYMBOL CAMPOW = GPIO.4
    SYMBOL CAMSHUT = GPIO.5
    GPIO0NEW VAR BYTE
    GPIOOOLD VAR BYTE
    GPIO1NEW VAR BYTE
    GPIO1OLD VAR BYTE
    GPIO3NEW VAR BYTE
    GPIO3OLD VAR BYTE
    I VAR BYTE
    J VAR BYTE
    K VAR BYTE
    L VAR BYTE
    M VAR BYTE
    N VAR BYTE
    O VAR BYTE
    P VAR BYTE
    Q VAR BYTE
    OUTPUT GPIO.2
    HIGH GPIO.2
    TRISIO = %00001011
    OPTION_REG = %00001000;
    WPU = 00001011
    CMCON = 7 ;
    INTCON = %10000000 ; Set GIE - clear interrupt enable bit and flags.
    IOCB = %00001011
    low CAMPOW
    LOW CAMSHUT
    J = 0
    i = 0
    M = 0
    K = 0
    L = 0
    N = 0
    O = 0
    P = 0
    PAUSE 20000
    low GPIO.2
    PAUSE 500
    HIGH GPIO.2
    GOTO BASE
    MYINT:
    GPIO0NEW = GPIO.0
    GPIO1NEW = GPIO.1
    GPIO3NEW = GPIO.3
    IF GPIO0NEW <> GPIOOOLD THEN
    Q = 1
    GOTO CAM
    IF GPIO1NEW <> GPIO1OLD THEN
    L=1
    M = 1 + M
    IF M > 3 THEN
    M = 1
    FOR i = 1 TO M
    LOW GPIO.2
    PAUSE 200
    HIGH GPIO.2
    PAUSE 200
    NEXT I
    GPIO1OLD = GPIO.1
    GPIO3OLD = GPIO.3
    GPIOOOLD = GPIO.0
    RESUME BASE
    IF GPIO3NEW <> GPIO3OLD THEN
    j = 1
    IF M = 1 THEN
    GOTO DELAYS
    IF M = 2 THEN
    GOTO DNB
    IF M = 3 THEN
    GOTO CMODE
    DELAYS:
    K = K + 1
    IF K = 6 THEN
    K = 1
    FOR i = 1 TO K
    LOW GPIO.2
    PAUSE 500
    HIGH GPIO.2
    PAUSE 500
    NEXT I
    IF K = 1 THEN
    N = 1
    IF K = 2 THEN
    N = 25
    IF K = 3 THEN
    N = 51
    IF K = 4 THEN
    N = 257
    IF K = 5 THEN
    N = 1029
    GPIO3OLD = GPIO.3
    GPIO1OLD = GPIO.1
    GPIOOOLD = GPIO.0
    RESUME BASE
    DNB:
    K = K + 1
    IF K > 3 THEN
    K = 1
    FOR i = 1 TO K
    LOW GPIO.2
    PAUSE 500
    HIGH GPIO.2
    PAUSE 500
    NEXT I
    O = K
    GPIO3OLD = GPIO.3
    GPIO1OLD = GPIO.1
    GPIOOOLD = GPIO.0
    RESUME BASE
    CMODE:
    K = K + 1
    IF K > 3 THEN
    K = 1
    FOR i = 1 TO K
    LOW GPIO.2
    PAUSE 500
    HIGH GPIO.2
    PAUSE 500
    NEXT I
    P = K
    GPIO3OLD = GPIO.3
    GPIO1OLD = GPIO.1
    GPIOOOLD = GPIO.0
    RESUME BASE
    CAM:
    INPUT GPIO.2
    WPU = 00001111
    IF O = 2 AND GPIO.2 = 1 THEN
    OUTPUT GPIO.2
    WPU = 00001011
    GPIO3OLD = GPIO.3
    GPIO1OLD = GPIO.1
    GPIOOOLD = GPIO.0
    RESUME BASE
    IF O = 3 AND GPIO.2 = 0 THEN
    OUTPUT GPIO.2
    WPU = 00001011
    GPIO3OLD = GPIO.3
    GPIO1OLD = GPIO.1
    GPIOOOLD = GPIO.0
    RESUME BASE
    OUTPUT GPIO.2
    WPU = 00001011
    IF P = 1 THEN
    GOTO SCAMR
    IF P = 2 THEN
    GOTO DPM
    IF P = 3 THEN
    GOTO MOVMODE
    SCAMR:
    HIGH CAMPOW 'PRESS POWER
    PAUSE 500 'HOLD POWER FOR 500 MILLISECOND
    LOW CAMPOW 'RELEASE POWER
    pause 2200
    HIGH CAMSHUT 'PRESS SHUTTER FOR 2 SECOND
    PAUSE 3000
    LOW CAMSHUT 'RELEASE SHUTTER
    PAUSE 8000 'ALLOW 8 MORE SECONDS TO SAVE AND TURN CAMERA OFF
    HIGH CAMPOW 'TURN CAMERA OFF
    PAUSE 500
    LOW CAMPOW
    GPIOOOLD = GPIO.0
    GPIO3OLD = GPIO.3
    GPIO1OLD = GPIO.1
    RESUME BASE
    DPM:
    pause 2200
    PAUSE 3000
    PAUSE 6000 'ALLOW 8 MORE SECONDS TO SAVE AND TURN CAMERA OFF
    HIGH CAMSHUT 'TURN CAMERA OFF
    PAUSE 500
    LOW CAMSHUT
    PAUSE 500
    LOW CAMPOW
    GPIOOOLD = GPIO.0
    GPIO3OLD = GPIO.3
    GPIO1OLD = GPIO.1
    RESUME BASE
    MOVMODE:
    pause 2200
    PAUSE 3000
    PAUSE 17000 'ALLOW 8 MORE SECONDS TO SAVE AND TURN CAMERA OFF
    PAUSE 500
    LOW CAMSHUT
    PAUSE 500
    LOW CAMPOW
    GPIOOOLD = GPIO.0
    GPIO3OLD = GPIO.3
    GPIO1OLD = GPIO.1
    RESUME BASE
    REFRESH:
    PAUSE 5000
    GOTO LOOP
    BASE:
    IF J = 1 THEN
    WRITE 1,K
    WRITE 3,N
    WRITE 4,O
    WRITE 5,P
    IF L = 1 THEN
    WRITE 2,M
    J = 0
    L = 0
    READ 1,K
    READ 2,M
    READ 3,N
    READ 4,O
    READ 5,P
    INTCON = %10001000 ; Set/re-set interrupt enable bit - clear flags
    ON INTERRUPT GOTO MYINT
    IF Q = 1 THEN
    GOTO DSLEEP
    LOOP:
    SLEEP 3088
    GOTO REFRESH
    GOTO LOOP
    DSLEEP:
    IOCB = %00001010
    SLEEP N
    IOCB = %00001011
    Q = 0
    GOTO LOOP
    Never mind, I evidently was losing my hair from head up the butt disease.
    Quote Originally Posted by BGreen View Post
    LOOP:
    SLEEP 3088
    GOTO REFRESH
    GOTO LOOP
    DSLEEP:
    IOCB = %00001010
    SLEEP N
    IOCB = %00001011
    Q = 0
    GOTO LOOP
    You realize that the program will never get to that 2nd 'GOTO LOOP' right?
    If Q = 1 it does. I had rechecked resumes til I was blue in the face. I had left out an obvious one. Thanks for the input Skimask
    Let me try that again...
    LOOP:
    SLEEP 3088
    GOTO REFRESH
    GOTO LOOP
    DSLEEP:
    IOCB = %00001010
    SLEEP N
    IOCB = %00001011
    Q = 0
    GOTO LOOP
    I didn't mean the 2nd GOTO LOOP, I meant the 1st one.
    GOTO REFRESH goes to REFRESH:
    The GOTO LOOP after GOTO REFRESH will never get executed.
    You are right. That command will never be executed. Actually it was redundant and a waste of code space. Thanks.
    So, did you fix the problem or what?
    My problem was fixed when I pulled my head out of my butt.
    New England
    LOL - That's how most of my problems get fixed too! :-()
    Arch
    "Data sheets? I ain't got no data sheets. I don't need no data sheets. I don't have to read any stinking data sheets!"
  1. Help! My 'interupt', erhm ...only interupts the one time?!!!
    Last Post: - 2nd November 2009, 13:49
  2. Strange LCD Behavior
    By chips123 in forum mel PIC BASIC Pro
    Last Post: - 1st November 2009, 01:48
  3. Strange behavior - PORTG.2, 18F8720
    Last Post: - 12th January 2009, 00:30
  4. Strange electrical behavior with PIC16F684
    Last Post: - 28th March 2008, 07:58
  5. Strange PortA behavior on 18F PIC
    By Terry in forum mel PIC BASIC Pro
    Last Post: - 17th August 2007, 23:31
