Defining MCU with MPASM
Results 1 to 7 of 7
    Default Defining MCU with MPASM
    I decided after a long time of resistance to leave PM assembler and start using MPASM. Up to this moment I could not find a way to define the use of PIC type in my program like the usual
    @ device pic18fxxx
    in PM assembler.
    Wink
    HI, Ioannis
    I didn't find nor ... that way.
    BUT ... if you use The MPLAB Project Wizard ( you should !!! )... you define the processor there and do not need to define it in your program !!!
    Thanks Alain. When using Mpasm, to assemble my program, it is funny, I cannot bootload it to the PIC. It seems that the mcu should be defined in the Basic program. I'll have to dig further and see what causes this to happen.
    Wink
    Ha ! Bootloaders and Hex files ...
    1) in MPLAB : Configure/Select Device
    2) Select your programmer
    2) " : FILE / Import " my bootloader.hex "
    3) " : View / Program memory ( optionnal ... but useful !!! )
    4) Program the bootloder ...
    Here it is ...
    Hi Alain.
    I have already loaded the PIC with the appropriate bootloder hex code. It is working just fine with any program created from PBP with it's own assembler. But it is not working with Mpasm!
    Of course I can always load the new hex file without Bootloader, but...
    Wink
    I do not know any real Bootloading directly from MPLAB ...
    download AN 851 and its softs from Microchip Website ... interesting - and useful !!!
    do not forget to (copy into the "Program Files/P1618QP" directory)
    : http://ww1.microchip.com/downloads/e...618QP_v1_1.zip
    and select AN851 as a programmer ...
    For REAL Bootloaders ( free ... ) see here :
    http://www.etc.ugal.ro/cchiculita/so...bootloader.htm
    Thanks, I'll check it. Indeed interesting!
  1. 12F675 MCLR directive MPASM
    By OLDSCHOOL in forum mel PIC BASIC Pro
    Last Post: - 4th May 2008, 01:29
  2. MPASM vs PM
    Last Post: - 10th October 2007, 01:29
  3. MPASM 18F4550 getting started
    Last Post: - 4th September 2007, 23:59
  4. 18F8722 and MPASM confusion!
    By Jackson in forum mel PIC BASIC Pro
    Last Post: - 2nd April 2006, 01:24
  5. Converting to MPASM
    Last Post: - 4th November 2005, 01:35
