TRIS E setting for 18F2550
Results 1 to 4 of 4
    Oct 2003
    Australia
    Default TRIS E setting for 18F2550
    Hi Guys,
    I want to use Pin 1 (TrisE/MCLR input) as a digital input and having problems trying to set TRISE.3 as a digital input.
    I get error [113] symbol not previously defined.
    I've set CONFIG MCLRE = OFF in the .inc file to disable MCLR, but that doesn't help.
    I know it's simple but just can't figure it out.....
        ' SETUP THE PORTS
        ADCON1 = $0F
        SSPCON1 = 0
        CMCON = $07
        TRISA = $FF
        TRISB = %00000001
        TRISC = %00000001
        TRISE = %11111111
    Cheers
    Squib
    Quote Originally Posted by Squibcakes View Post
    Hi Guys,
    Cheers
    Squib
    If you program and then do a readback of the '2550, is the MCLRE bit still set or reset?
    Sounds to me like the CONFIG isn't being set in the PIC itself.
    Feb 2003
    Salt Lake City, Utah USA
    Smile
    Something to try ...try this in your .inc file
          __CONFIG    _CONFIG3H, _PBADEN_OFF_3H & _MCLRE_OFF_3H
    EDIT - In the above, I added the "_MCLRE_OFF_3H" to the already exisiting __CONFIG _CONFIG3H line of the inc file
    Last edited by paul borgmeier; - 23rd May 2007 at 06:24. Reason: clarity & format change (& instead of ,)
    Paul Borgmeier
    Salt Lake City, UT
    USA
    __________________
    Oct 2003
    Australia
    Ok thanks guys sussed it.
    I was right in the fist place to use CONFIG MCLRE = OFF , the only thing is that I didn't need to use TRISE = ....., This pin is input only anyway.
    Cheers
    Squib
  1. TRIS setting for the DS1302
    By Dennis in forum mel PIC BASIC Pro
    Last Post: - 3rd March 2010, 01:14
  2. OSCON setting for 18F4520
    Last Post: - 29th November 2009, 15:18
  3. PICKit2 - warning about configuration words
    Last Post: - 4th August 2009, 14:01
  4. Help with setting adcon1 for 16f877
    Last Post: - 16th August 2005, 11:13
  5. Is LCDOUT setting always al TRIS ?
    By BigWumpus in forum mel PIC BASIC Pro
    Last Post: - 19th June 2005, 17:02
