From the options along the main toolbar select VIEW > PROGRAMER & COMPILER OPTIONS and the either browse to the PicBasic Pro EXE or click on the button that will find the exe. Then do the same for the assembler ( I use MPSAM which is part of the MPLAB download from Microchip - and have the check box enabled - otherwise you can use the inbuilt assembler with PBP). Finally you can also do the same for the programmer you are using which will launch the software to squirt the HEX code to the PIC
