MCP23016 missing D7 on I2CRead
Results 1 to 2 of 2
    May 2007
    Question MCP23016 missing D7 on I2CRead
    I have a PIC 16F876A running at 4 Mhz, interfaced via I2C, to a PIC MCP23016 ( TP @ 1 Mhz )
    The SCL (portc.3) & SDA(portc.4) lines are pulled to Vcc via 4.7K
    Variables were used for the control, address, and data portions of the I2CRead statement.
    I was successful at setting up and using the MCP as an 8/16 bit output device as well as an 8/16 bit input device.
    I did run into an anomaly when using it as an input device.
    The bits for the two registers GP0 and GP1 were read back from the MCP but bit D7 was missing from the first register that was read. A scope reading revealed that the first SCL clock pulse #1 after the internal read was missing or shortened to a glitch. ( see PIC data sheet DS20090B, FIG 1.7 ).
    By reducing the Cext to 15 pf from the recommended 33 pf ( ie. increasing the internal MCP clock to 2 Mhz) the # 1 clock pulse was restored. Even better results occured when I used only the stray capacitance of the bread board to increase TP to 4 Mhz.
    It would appear that the MCP is holding the SCL line down long enough to distort or eliminate SCL pulse #1. By increasing the internal MCP clock speed, the MCP processes the data faster reducing the hold down time for SCL?
    This would seem to be a dubious fix for this problem.
    I'm hoping one of the forum members has run into this problem and can suggest a few more things for me to try or check.
    thank you in advance,
    TWSK
    May 2007
    Question Pic Basic and I2C Master wait states ?
    Quote Originally Posted by TWSK View Post
    TWSK
    The I2C specification states:
    The I2C-bus specification
    7 TRANSFERRING DATA
    7.1 Byte format
    .................................................. ......If a slave can’t
    receive or transmit another complete byte of data until it
    has performed some other function, for example servicing
    an internal interrupt, it can hold the clock line SCL LOW to
    force the master into a wait state. Data transfer then
    continues when the slave is ready for another byte of data
    and releases clock line SCL.
    Questions: ( to any I2c GURU s )
    Does the Pic BASIC Pro I2cread command respond to the SCL line being held low by the slave?
    Is there a time limit on how long the Pic Basic Pro master waits for the SCL line to be released by the slave?
    It looks like the read of D7 was only successful when the slave's processing time was reduced so the wait time ( SCL held low ) was reduced and the master clock pulse 1 became viable as the slave was no longer "stepping" on it.
  1. I2C and MCP23016
    By keymuu in forum mel PIC BASIC Pro
    Last Post: - 14th January 2009, 12:27
  2. PIC18F4550 Error[128] Missing Arguments
    By damalu in forum mel PIC BASIC
    Last Post: - 17th November 2008, 22:47
  3. MCP23016 I2C serial I/O expander chip
    By GeoJoe in forum Serial
    Last Post: - 31st October 2007, 16:39
  4. PFC8583 Connection and I2Cwrite I2cread!
    By uludere72 in forum mel PIC BASIC Pro
    Last Post: - 27th February 2006, 14:32
  5. MCP23016 I/O expander with PBP?
    By Jon Chandler in forum mel PIC BASIC Pro
    Last Post: - 22nd August 2005, 10:32
