POT command
Results 1 to 4 of 4
Thread: POT command
    Helios, The POT command executes a charge and discharge of a capacitor connected to a resistor (pot) connected to 1 pin of the processor. The time is then measured and a value is made available. For the input you have available you will need an A/D channel to evaluate the speed. Sorry.....
    Wink A/D Without A/D chip ... possible !!!
    Hi, Helios ( The sun ... wow !!! )
    Try to use RCTime instead of POT, to measure a voltage ... there are applications on the Web.
    BUT you'll have to use a Lookup table ... as response to voltage give an exponential law.
    also ... no measure below 1.5v !!!
    See µChip DS 40040B
    See Nuts and Volts Vol1 p 133 ( Parallax site ) : The real way of POT working !!!
    see also : http://www.emesystems.com/BS2rct.htm
    MY Thought ... if you see how simple it is to use an ADC ( PIC or outside ) ... the soft programming work with POT orRCTime looks like using a hammer and chisel to program the Chip !!!
    Apr 2007
    thanks guys for help, i really appreciate this
    and i 'll use the A/D instead of POT after i saw the site which acetronics sent ... it is a hilti issue :d
    thanks again.
  1. Using the Pot command.
    By timseven in forum mel PIC BASIC Pro
    Last Post: - 17th August 2009, 21:23
  2. PBP2.50b and POT command problem ?
    Last Post: - 13th October 2008, 18:14
  3. Replies: 4
    Last Post: - 24th January 2007, 23:20
  4. pot command
    Last Post: - 25th November 2006, 05:12
  5. Can I do this???
    By noobie in forum mel PIC BASIC
    Last Post: - 10th June 2006, 19:57
