Hserout
Results 1 to 19 of 19
Thread: Hserout
    MICOCALI's Avatar
    MICOCALI Guest
    Default Hserout
    I SEND THE CARACTER TO PIC AT PC WITH 9600/8/E/1
    i HAVE CONFIG DEFINE HSER_EVEN 1, BUT THE COMUNICATE IS 9600/7/E/1. WHAT IS THE DEFINE?
    1. For 7E1 add the define...
    DEFINE HSER_EVEN 1
    2. For 7O1 add the define...
    DEFINE HSER_ODD 1
    3. For 8N1...
    Do NOT add any defines
    The following additions below are only valid for PBP 2.44 or later...
    4. For 8E1...
    Define HSER_EVEN 1
    Define HSER_BITS 9
    5. for 8O1
    Define HSER_ODD 1
    Define HSER_BITS 9
    Note that options 4 & 5 are ONLY available from PBP version 2.44 onwards which added the HSER_BITS 9 define. If you have an older compiler, it's time to get in contact with MeLabs for an upgrade.
    Melanie
    MICOCALI's Avatar
    MICOCALI Guest
    I have 2.44 but HSER_BITS 9 NOT COMPILE THIS DEFINE
    MICOCALI's Avatar
    MICOCALI Guest
    Unhappy
    DEFINE OSC 20
    DEFINE HSER_RCSTA 90h
    DEFINE HSER_TXSTA 24h
    DEFINE HSER_BAUD 9600
    DEFINE HSER_CLROERR 1
    DEFINE HSER_EVEN 1
    DEFINE HSER_BITS 9
    I HAVE THIS DEFINE BUT THE COMUNICATE IS 8N1
    WHY
    Define HSER_BITS 9
    Compiles without error with my version of 2.44
    MICOCALI's Avatar
    MICOCALI Guest
    IF POSSIBLE COMPILE THIS FILE FOR ME
    THANK
    MICOCALI's Avatar
    MICOCALI Guest
    THE PIC IS 16F628
    I've compiled it twice for you... (two posts since I can only add one attachment at a time)...
    This is done with PBP version 2.44
    It is actually a .HEX file, but again this forum doesn't allow .HEX attachments so I renamed it as a .TXT
    And this is compiled with PBP version 2.45
    Feb 2004
    Germany
    @ Melanie
    you are right, the example compiles ok
    but what MICOCALI is saying is also correct.
    I have just tried it with:
    DEFINE LOADER_USED 1
    DEFINE OSC 20
    DEFINE HSER_EVEN 1
    DEFINE HSER_BITS 9
    Loop:
    Hserout ["Test: 0 1 2 3 4 5 6 7 8 9"]
    Pause 1000
    goto loop
    The PIC communitates with 9600 8N1
    MICOCALI's Avatar
    MICOCALI Guest
    thank you NavMicroSystems
    but I make connection with pic at 9600/8/E/1
    i HAVE USE THE FILE PANA245 BUT COMUNICATION IS 8N1
    NOT 8E1 I HAVE TESTED WITH HYPERTERMINAL
    Have you checked that you get the same erroneous result with PBP244 and PBP245?
    MICOCALI's Avatar
    MICOCALI Guest
    I HAVE TESTED PANA 244 AND PANA 245 BUT THE COMUNICATION IS 8N1 WHY ALL THIS?
    It looks like HSER_BITS 9 was added when the HSEROUT2 and HSERIN2 commands (along with the HSER2_BITS define) were added.
    I'll pull a PIC out with 2 USARTS and test both HSEROUT and HSEROUT2 later when I've some free time.
    You can of course BYPASS the HSEROUT defines and set-up the PIC's registers manually...
    MICOCALI's Avatar
    MICOCALI Guest
    IN WICH MODE ?
    Just as a test... before we dive into playing with the registers... you're currently setting HSER_TXSTA to 24h. Since bit 6 of the TXSTA Register selects 8 or 9 bit mode, shouldn't you really be setting TXSTA to 64h??
    Therefore try these defines...
    DEFINE OSC 20
    DEFINE HSER_TXSTA 64h
    DEFINE HSER_EVEN 1
    DEFINE HSER_BITS 9
    MICOCALI's Avatar
    MICOCALI Guest
    YOU ARE THE BEST THANK YOU FOR ALL
    Another happy customer... *smiles*
    Feb 2004
    Germany
    Melanie,
    you are so right!
    In most cases a look at the datasheet really helps!
    As I have a Board in front of me I have tested it, and with
    and the PIC communicates @ 9600 8E1
  1. I2C Slave with a PIC
    By ralfmayr in forum mel PIC BASIC Pro
    Last Post: - 21st August 2016, 18:44
  2. hserin and sms controller
    By xxxxxx in forum mel PIC BASIC Pro
    Last Post: - 10th February 2010, 16:49
  3. HSEROUT and Commas, What? Help Me Understand
    By altech6983 in forum mel PIC BASIC Pro
    Last Post: - 20th July 2009, 20:12
  4. Is HSEROUT corrupting bit 7 ?????
    By Robert Wells in forum mel PIC BASIC Pro
    Last Post: - 23rd October 2008, 17:26
  5. Controlling an 240x128 LCD Touchpanel Display
    By Vincent in forum mel PIC BASIC Pro
    Last Post: - 8th June 2006, 00:36
