Is there a simple windows based hex editor for looking at .bmp files on disk that someone could reccomend?
I need it to find where the image data begins in a file, either on hard disk or an SD card. Freeware would be good!
Ron
Ron
http://www.fortunecity.com/skyscrape.../bmpffrmt.html
http://local.wasp.uwa.edu.au/~pbourke/dataformats/bmp/
Sure it's doable.
I use bpsoft Hex WorkShop... but it's not free.
http://www.hexworkshop.com/
BUT
http://www.hhdsoftware.com/Products/...itor-free.html
i have few HHD soft software here and they are excellent, so the above should be nice
and then the usual
http://www.google.ca/search?hl=en&q=...G=Search&meta=
ONE MORE
http://www.bestvistadownloads.com/so...-ngznwbou.html
Thanks Steve,
I'm just dubbing now and I hate to invest substantially in a piece of software for a project that may have no practical application.
Ron
I bought the Hex workshop. It is inexpensive, and should be bug free.
Ron
GOOD! Smart choice!
I use it often to edit/create Text EEPROMs. Easy to figure out how your LCD scren (of any type) will looks like.
The only issue is there seems to be a lot of data bytes that appear to do nothing before the image file. I need to find the file format to find out what it all does!
Well, the first link i've posted was for an old BMP format i think, sure there's other info on much recent format such as 24, 32 bits one somewhere.
You should be able to find some info a long with source code on PSC that explains the file structure of a Bitmap. I don't think the format of them is terribly
complex, nothing anywhere near as difficult as a jpeg or animated gif. Happy searching! http://www.planetsourcecode.com
Here is a link for the BMP format..
http://www.odec.ca/projects/2004/chi...mpresearch.htm
Anyone have any ideas for code to extract the pixel data? I would suspect it to be something like open the .BMP for read, then open an ASCII file for write, and then stream the data through the PIC...
I have an application coming up where I need to determine the randomness of dots in a balck and white BMP image. I'll post anything I come up with here... stay tuned
Bron
The less you expect, the more you get.
