DS1820 headache
Results 1 to 12 of 12
Thread: DS1820 headache
    Calco's Avatar
    Calco Guest
    Default DS1820 headache
    Hi all,
    Ive got a small problem with a DS1820 setup.
    Iam using a 16F819 with its internal osc at 8mhz.
    I have modified the onewire.bas so as to send the data serially.
    My display simply reads 85.0 C constantly. It doesnt alter when temperature is applied either.
    Occasionally it will read 26.89 C but only briefly and only just after power up.
    My question is, is timing accuracy critical on these?, What am I missing?
    Iam currently unable to put an LCD module direct to the PIC.
    Iam running a serial LCD module.
    Hope someone can ppoint me in the right direction.
    Darryl
    Is 85 the raw value retuned from the device (which would be absolute zero and a meaningless result), or is this the converted value to something meaningful like degrees C or F?
    Might help if we saw the OWIN/OWOUT code part where you interrogate the sensor.
    edwards_jt's Avatar
    edwards_jt Guest
    Hi, I might be having the same problem as well, i am using the ds18b20.
    I am not sure yet, i think my problem might be with the timing pof the Tx/Rx. I couldn't get the owin and owout routines to work so i wrote new ones based on the example at http://www.rentron.com/PICX4.htm
    with some timing tweaks based on the datasheet for the ds18b20.
    I havn't managed to get an lcd working so there is led flashing to illustrate different steps in the program cycle as well as to output the raw two's compliment data.
    No matter what i do the results for all 9 bytes of the scratchpad are the same (including taking a soldering iron to the ds18b20!) and the crc byte (9th byte). I have checked this program with two ds18B20's (all i have) and both output exactly the same data, so like i said probably a timing error in the tx/rx.
    btw - i wrote the program using the mikroelectronica mikrobasic compiler since it was free, after some frustration i bought PBP 2.45 and now am trying to migrate this program to PBP, you should be able to follow it well enough, the syntax is extremely similar. I am programming a pic 16f684.
    let me know what you think, it may be useful to compare what i am doing wrong to what you are doing wrong
    cheers,
    James
    Feb 2004
    Germany
    The following example works just fine
    make sure yor DS1820 has +5V on Pin 3
    If you are using the "Parasite Power" Option
    you need to set DQ high right after starting the conversion
    regards
    edwards_jt's Avatar
    edwards_jt Guest
    Thanks, actually where i went wrong on the reynolds example was the cmcon0 register was incorrectly set for the 16f684 (needed update from melabs 2.45 --> 2.45a)
    so i have a program that seems to read the 12 bit temperature from the ds18b20 ... only one problem, when i convert from twos compliment it reads garbage, but if i leave the data as is and output it, it makes perfect sense, accurate as well as i can tell without a full blown calibration and its responsive to stimuli (body temp and soldering iron)
    now I usually follow the motto in electronics 'if it works, don't ask' (i only have a year of electronics from university and i never covered microcontrollers, so its a good motto) but i find this disconcerting. Any ideas why this set-up would read the data in this way? I have attached the code but nothing i can see in it reverses the data ?
    so any ideas?
    James
    edwards_jt's Avatar
    edwards_jt Guest
    sorry, the attachment doesn't seem to want to go, this is the working code i have for the 16f684
    'circuit
    'a0 to pin2 of ds1820 with 4.7k pullup to vdd
    'portc 0-->5 connected to LEDs in series with 100 Ohm resistor
    'porta(1,2) connect to LEDs in series with 100 Ohm resistor
    'chip specific definitions
    @ DEVICE pic16F684, INTRC_OSC_NOCLKOUT
    ' System Clock Options (Internal)
    @ DEVICE pic16F684, WDT_on
    ' Watchdog Timer
    @ DEVICE pic16F684, PWRT_ON
    ' Power-On Timer
    @ DEVICE pic16F684, MCLR_OFF
    ' Master Clear Options (Internal)
    @ DEVICE pic16F684, BOD_Off
    ' Brown-Out Detect
    @ DEVICE pic16F684, CPD_OFF
    ' Data Memory Code Protect
    @ DEVICE pic16F684, PROTECT_OFF
    ' Program Code Protection
    @ DEVICE pic16F684, extrc_osc_noclkout
    ' set sfr
    intcon=%00000000 ' disables cpu interupts
    pie1=%00000000 ' disables all periphrial interupts
    ansel=%00000000 ' diables analog inputs
    TRISC=%00000000 ' sets port c to output
    TRISA=%00000000 ' sets port a
    cmcon0=7
    ADCON1 = 7 ' disables a/d
    wpua = 6 ' enables weak pull ups on pins a1 and a2
    ' Allocate variables
    command VAR BYTE ' Storage for command
    i VAR BYTE ' Storage for loop counter
    temp VAR WORD ' Storage for temperature
    DQ VAR PORTA.0 ' Alias DS1820 data pin
    DQ_DIR VAR TRISA.0 ' Alias DS1820 data direction pin
    ' main program loop
    GoSub flash ' shows loop start
    Pause 1000
    GoSub init1820 ' Init the DS1820
    command = $cc ' Issue Skip ROM command
    GoSub write1820
    command = $44 ' Start temperature conversion
    GoSub write1820
    Pause 2000 ' Wait 2 seconds for conversion to complete
    GoSub init1820 ' Do another init
    GoSub write1820
    command = $be ' Read the temperature
    GoSub write1820
    GoSub read1820
    GoSub flash ' shows loop end
    Pause 1000
    ' outputs lower byte on LEDs
    For i=1 TO 200
    IF temp.0 = 1 Then
    PORTC.0 = 1
    EndIF
    IF temp.1 = 1 Then
    PORTC.1 = 1
    EndIF
    IF temp.2 = 1 Then
    PORTC.2 = 1
    EndIF
    IF temp.3 = 1 Then
    PORTC.3 = 1
    EndIF
    IF temp.4 = 1 Then
    PORTC.4 = 1
    EndIF
    IF temp.5 = 1 Then
    PORTC.5 = 1
    EndIF
    IF temp.6 = 1 Then
    PORTA.1 = 1
    EndIF
    IF temp.7 = 1 Then
    PORTA.2 = 1
    EndIF
    Pause 10
    PORTC=0
    PORTA.1=0
    PORTA.2=0
    Pause 200
    Next i
    'flashes LEDs between bytes
    PORTC=0
    PORTA.1=0
    PORTA.2=0
    PORTC=%111111
    PORTA.1=1
    PORTA.2=1
    Pause 2000
    PORTC=0
    PORTA.1=0
    PORTA.2=0
    'outputs upper byte on LEDs
    For i=1 TO 200
    IF temp.8 = 1 Then
    PORTC.0 = 1
    EndIF
    IF temp.9 = 1 Then
    PORTC.1 = 1
    EndIF
    IF temp.10= 1 Then
    PORTC.2 = 1
    EndIF
    IF temp.11= 1 Then
    PORTC.3 = 1
    EndIF
    IF temp.12= 1 Then
    PORTC.4 = 1
    EndIF
    IF temp.13= 1 Then
    PORTC.5 = 1
    EndIF
    IF temp.14= 1 Then
    PORTA.1 = 1
    EndIF
    IF temp.15= 1 Then
    PORTA.2 = 1
    EndIF
    Pause 5
    PORTC=0
    PORTA.1=0
    PORTA.2=0
    Pause 200
    Next i
    GoTo main ' Do it forever
    ' Initialize DS1820 and check for presence
    init1820:
    Low DQ ' Set the data pin low to init
    PauseUs 500 ' Wait > 480us
    DQ_DIR = 1 ' Release data pin (set to input for high)
    PauseUs 100 ' Wait > 60us
    IF DQ = 1 Then
    PORTC=%00000011
    PORTA.1=1
    PORTA.2=1
    Pause 2000
    PORTC=0
    PORTA.1=0
    PORTA.2=0
    GoTo main ' Try again
    Else
    PORTC=%11111111
    PORTA.1=1
    PORTA.2=1
    Pause 2000
    PORTC=0
    PORTA.1=0
    PORTA.2=0
    EndIF
    PauseUs 400 ' Wait for end of presence pulse
    ' Write "command" byte to the DS1820
    write1820:
    For i = 1 TO 8 ' 8 bits to a byte
    IF command.0 = 0 Then
    GoSub write0 ' Write a 0 bit
    Else
    GoSub write1 ' Write a 1 bit
    EndIF
    command = command >> 1 ' Shift to next bit
    Next i
    ' Write a 0 bit to the DS1820
    write0:
    Low DQ
    PauseUs 60 ' Low for > 60us for 0
    ' Write a 1 bit to the DS1820
    write1:
    Low DQ ' Low for < 15us for 1
    @ nop ' Delay 1us at 4MHz
    PauseUs 60 ' Use up rest of time slot
    ' Read temperature from the DS1820
    read1820:
    For i = 1 TO 16 ' 16 bits to a word
    temp = temp >> 1 ' Shift down bits
    GoSub readbit ' Get the bit to the top of temp
    Next i
    ' Read a bit from the DS1820
    readbit:
    temp.15 = 1 ' Preset read bit to 1
    Low DQ ' Start the time slot
    IF DQ = 0 Then
    temp.15 = 0 ' Set bit to 0
    EndIF
    PauseUs 60 ' Wait out rest of time slot
    flash:
    For i=1 TO 20
    PORTC=%11111111
    PORTA.1=1
    PORTA.2=1
    Pause 50
    PORTC=0
    PORTA.1=0
    PORTA.2=0
    Pause 200
    Next i
    Calco's Avatar
    Calco Guest
    Melanie,
    Thanks, I have managed to sort it out now, it turns out that 85 is the default value stored in the DS1820 and if you do not connect 5v to pin 3 as had been previously suggested then it is unable to alter the value. Im certain all my other units ran with just the 2 connections. I guess you live and learn.
    Darryl
    Feb 2004
    Germany
    Here is short example for DS1820 using OWIN and OWOUT
    DQ var PortD.2
    temp var word
    loop:
    owout DQ,1,[$cc]
    owout DQ,0,[$44]
    Pause 2000
    owout DQ,1,[$cc]
    owout DQ,0,[$be]
    owin DQ,0,[temp.byte0,temp.byte1]
    lcdout $FE,1
    temp=temp*5
    lcdout " Temp = ",DEC2 temp/10,".", dec1 temp," ",$DF,"C"
    goto loop
    regards
    actionplus's Avatar
    actionplus Guest
    Red face Thats it?
    NavMicroSystems
    the short that you posted, will that just do it? I will have to try it.
    I am try to buildS one using a thermistor since I need to go up to about 250F. DS18S20 will not go up there.
    Still trying to figure out the codes
    Feb 2004
    Germany
    actionplus
    the short version is tested and works.
    It does not check the presence of a DS1820, it assumes it is just there.
    If you would like to check the presence of the sensor youl will need some more code.
    actionplus's Avatar
    actionplus Guest
    Default Thanks
    I shall try it.
    anj's Avatar
    anj Guest
    The following code will read a single DS18B20 sensor ( non parasite powered ), and will check for sensor being present/unplugged during conversion. It also deals with negative temps, and i get around this by adding 50degC to the result, and removing it later as required.
    Ps It will also trap sensor errors where there is a pullup but no sensor, as well as no pullup and no sensor ( as they give different results.)
    tempAir VAR WORD ' Air Temp ( ambient )
    temp1 Var Word ' Temperature storage
    tempx var word
    temp2 Var Word ' Temperature storage
    dummy VAR BYTE
    TmpPos var Byte 'Temp pos or neg
    Tmp var Word 'Temp
    OWPORT var BYTE 'Pin the sensor is on
    NoSens var BIT 'Byte to check for sensors
    ' Main loop
    loop:
    ' Get AIR temp
    OWPORT = 13 ' Pins 13 maps to C.5 in a 28pin device
    GOSUB ReadOW
    tempAir = temp1 'now has corrected ( temp + 50deg ) << 4 to beat minus signs
    ' Get next temp
    OWPORT = ??
    etc etc
    goto loop
    ' Routine to read a one wire device ( Assumes single unit in full powered mode, not Parasite )
    ' Checks for sensors ( pulldowns on switched inputs detect if sensor in place )
    ReadOW:
    temp1 = 0 ' ( Temp + 50 ) * 16
    NoSens = 0 ' Sensor check failed bit
    TmpPos = 0 ' Sensor check
    OWOut OWPORT, 1, [$CC, $44] 'Start conversion process
    waitloop:
    OWIn OWPORT, 4, [dummy] ' Check for still busy converting
    temp1 = temp1 + 1 ' Need next bit to cover probe unplugging after conversion starts
    pause 10 ' max conversion time for 12bit temp is 750mSec max
    if temp1 > 75 then ' hence if get this far, abort so she doesnt hang
    NoSens = 1
    goto waitlost
    If dummy = 0 Then waitloop ' Not finished converting
    OWOut OWPORT, 1, [$CC, $BE] ' Request read of the temperature
    OWIn OWPORT, 0, [temp1.LOWBYTE, temp1.HIGHBYTE, TmpPos, Skip 5 ]
    if TmpPos = %11111111 then 'If pullup is there but no sensor
    NoSens = 1 'TmpPos comes back as all 1s
    waitlost:
    if NoSens then
    temp1 = 9999 'Ie failed
    ' DS18B20 in full 12 bit mode returns temp as a binary value in 1/16th deg C ( 0.0625 )
    ' We must check MSB of temp1. If it is 1 we have a neg value and this requires
    ' different processing. We calc this using temp2 = ~temp1 + %1
    ' To get rid of negatives in later processing, we send temp1 back moved up by 50 degrees
    ' as such all processing in further code requires no negative nos
    if temp1.bit15 = 1 then 'negative
    Lcdout "-"
    tempx = ~temp1 + %1 ' needed to calc correct display
    temp1 = ( 50 << 4 ) - tempx ' add 50 to ensure we always get positive nos
    tempx = temp1
    temp1 = ( 50 << 4 ) + temp1 ' add 50 to keep sweet with neg nos
    As a bit of further info, there are probs with the later version DS18B20s which may also be coming into it, which is why they were pulled from the market.
    The B6 die units have variable timing probs, and the B7 dies can lose their internal calibrations.
    Andrew
  1. DS1820 with 16f688
    Last Post: - 23rd May 2009, 06:07
  2. DS1820 display with 7-seg 4 digits
    By chai98a in forum Code Examples
    Last Post: - 10th April 2008, 14:12
  3. DS1820 and 18f2550
    By rjones2102 in forum mel PIC BASIC Pro
    Last Post: - 2nd October 2007, 19:11
  4. PIC lcd ds1820
    By wchpikus in forum mel PIC BASIC
    Last Post: - 24th May 2007, 15:46
  5. DS1820 again
    By paxmowa in forum mel PIC BASIC Pro
    Last Post: - 10th January 2006, 15:49
