16f628 for all outputs
Results 1 to 6 of 6
    Apr 2007
    Florida, USA
    Default 16f628 for all outputs
    I have tried about everything i know to get a 16f628 to blink my led. But to no avail. Is there some special config i need to set to have this action take place? I am just applying power, using the internal osc. set my comparator mode to 7. is there something else i should be doing?
    Quote Originally Posted by Max_Gauss View Post
    Are you using the PIC16F628 or the PIC16F628A?
    There's enough of a difference between the two to keep things from working.
    And post some code, a schematic, something, anything.
    For all I know you've got 3 buckets of grass clippings, 2 rocks, and a jar of mustard.
    Apr 2006
    New Hampshire USA
    Exclamation Does this help?
    Hi skimask,
    Here is a circuit attachment I found online you might find helpful.
    hth
    -Adam-
    <table><td><img SRC="http://www.picbasic.co.uk/forum/attachment.php?attachmentid=1629&stc=1&d=117919107 7"></td>
    <td>
    • Jar of mustard = +5V
    • RCK 1, RCK 2 = Gnd
    • GCB1, GCB2, GCB3 = LED + 330 OHM Resistor
    • PIC16F84 = something that should be removed from the market since 10 years, can happilly be replace by a 16F628. If you do it, remove the crystal + both 22pF capacitor and try the code bellow
    </td></table>
    <font color="#000000">        <font color="#008000">'
            '       Pic Configuration
                    '       Here we will set the PIC configuration fuses
                    '       to use the internal PIC oscillator and disable the MCLR
                    '       pin.
            </font>@ __CONFIG  _INTRC_OSC_NOCLKOUT &amp; _MCLRE_OFF  &amp;  _LVP_OFF &amp; _WDT_OFF &amp; _PWRTE_ON  &amp; _BODEN_ON
                    '       This assume you're using MPASM to compile your code
                    '       For detailed information about Configuration fuse setting,
                    '       have a look to &quot;Presetting Configuration Fuses (PIC Defines)&quot; thread
                    '       in the forum FAQ section.
                    '           http://www.picbasic.co.uk/forum/showthread.php?t=543
            '       Hardware assignment
            </font>GCB_1   <font color="#000080">VAR </font>PORTB.0
            GCB_2   <font color="#000080">VAR </font>PORTB.1
            GCB_3   <font color="#000080">VAR </font>PORTB.2
            '       Hardware configuration
            </font>TRISB = 0               <font color="#008000">' Configure all PORTB i/o to output
            '       Software/Hardware initialisation
            </font>PORTB = 0
            <font color="#008000">'------------------------------&lt; Main program &gt;-----------------------------------
    </font>Start:  <font color="#008000">'
            '       Here will do the 'buckets of grass clippings' light show
            '       using a simple method... not the best
            </font>GCB_1 = 1
            <font color="#000080">PAUSE </font>500
            GCB_2 = 1
            GCB_3 = 1
            GCB_1 = 0
            GCB_2 = 0
            GCB_3 = 0
            <font color="#000080">GOTO </font>Start
    </font>
    Quote Originally Posted by Pic_User View Post
    Hi skimask,
    hth
    -Adam-
    Good answer!
    Oh Man! I near fell outta my chair!
    Apr 2007
    Florida, USA
    Default Thank You Gentlemen soo Much
    Thanks be to you all and my Lord Jesus..
    Each one of you have help me and i do so appreciate it. My 628 is now operable, and it is so wonderful.
    This was my problem.
    I was initially programming the 16f84 using MPLAB Assem. with PicStart Plus with upgrade. Then i bought PBP, which is so nice, and i changed to the 16f628. then using MIcroCode Studio i wrote a very simple piece to blink my LED. BUT .. NO blink.. I tried the 16f84.. NO blink.. WOW whats wrong. I tried 45 or 55 times .. NO. blink. I peruse to manuals. I went on internet. I called PBP, You've got to love them for they put up with such as i am. I joined this forum. I wrote the code in MicroCode Studio then selected "compile/Program". It would compile, then started up my MPLAB and leave me in the MPLAB screen. I would select my file. Set my config bits, and select my programmer, then program. There were NO errors, no issues. Also..NO blink. What it programmed into the chip, I have no idea. but it did programm and verify with no errors. What i did WRONG. When PBP brought up my MPLAB and I set my config bits, and selected my programmer.. I DID NOT compile my project in MPLAB.When PBP sends you to MPLAB, YOU have to compile the project. If you do not compile, it will programme something i know not what to the chip, but it will not work.. NOW my LED blinks.. Praise the Lord and thanks to you gentlemen soo much..
    jlittle
  1. 16F628 does not run. I can't believe this
    By Ioannis in forum mel PIC BASIC Pro
    Last Post: - 3rd October 2009, 16:41
  2. SERIN2 not working with 16F628
    By d1camero in forum mel PIC BASIC Pro
    Last Post: - 6th May 2004, 21:37
  3. 16F628 & In-Circuit Programming?
    By Len in forum mel PIC BASIC Pro
    Last Post: - 19th March 2004, 14:02
  4. 16F628 on-chip eeprom problem
    By atomski in forum mel PIC BASIC Pro
    Last Post: - 4th March 2004, 08:43
  5. need help configuring 16F628
    By tcbcats in forum mel PIC BASIC Pro
    Last Post: - 3rd March 2004, 19:59
