How come they make electronics hard as poss
Results 1 to 10 of 10
    Feb 2003
    That's a very good point. It's not like they couldn't standardize pin configurations.
    But some devices, particularly transistors are available in several pinouts for what is electrically the same device.
    BC182/BC182L (NPN) and its complimentary device BC212/BC212L (PNP) are in TO92 packages but with different pinouts.
    The non "L" version is TO92-4 EBC
    The "L" version is TO92-1 BCE
    Keith
    www.diyha.co.uk
    www.kat5.tv
    Feb 2003
    Thinking about it a bit more....
    Why are 78xx regulators IN-GND-OUT whereas 79xx regulators are GND-IN-OUT
    Keith
    www.diyha.co.uk
    www.kat5.tv
    T.Jackson's Avatar
    T.Jackson Guest
    Apart from possible intentions of helping to simplify PCB layout - it all makes no sense.
    well, if the tab was GND, then it would simplify the board layout. I'm guessing more about an internal structure rather than this... but everyone may have it's own assumption... only the original designer would probably know...
    thinking about reference in a dual rail supply... you could discover why they do it like that... is 79xxx really a 79xx or a 78xxx relabelled ??? i didn't compare their internal schematic.
    if everything would be standard, it would remove all fun...
    T.Jackson's Avatar
    T.Jackson Guest
    Post
    I don't think the internals force restrictions on anything. It's about the size of a head on a matchstick in most cases. But hey, I don't work in Silicon Valley, so I place no bets on anything.
    Omaha, Nebraska USA
    Believe it or not, this same complaint surfaced many years before transistors and integrated circuits!
    The issue (this was back when the Earth's crust was still cooling) was why can't the same kinds of vacuum tubes (i.e., diode, dual diode, triode, etc.) have the same pinout?
    In those days (there was no Silicon Valley and you could still afford to buy a house in California), the issue had to do, always first and foremost, with both the electrical characteristics of the device and good engineering practice.
    And, in the end, the same thing occurred--two vacuum tubes, identical or nearly so, would have different pinouts.
    Russ
    N0EVC, xWB6ONT, xWN6ONT
    "Easy to use" is easy to say.
  1. The Future Of Hobby Electronics.
    By T.Jackson in forum Off Topic
    Last Post: - 2nd February 2009, 06:39
    Last Post: - 14th November 2008, 17:25
  3. PBP is driving me crazy trying to make an 18F chip blink
    By George in forum mel PIC BASIC Pro
    Last Post: - 20th June 2008, 06:08
  4. In Tribute of Electronics Australia
    Last Post: - 28th May 2008, 07:43
  5. Replies: 3
    Last Post: - 10th April 2008, 10:02
