Displaying messages with only 7 (or 4) LEDs on a stick...
Results 1 to 16 of 16
    SWITZERLAND (french speaking)
    Default Displaying messages with only 7 (or 4) LEDs on a stick...
    Hello,
    I have trouble in making a stick with leds for displaying message like this example below (this picture is not mine: it was found in internet).
    <img src=http://www.picbasic.co.uk/forum/attachment.php?attachmentid=1627&stc=1&d=117907003 3">
    Instead of 7 LEDs, I have only 4 to display letters; but it should work not too bad...
    Currently, I have split one caracter into five sequences (or colons) and light them up for 3ms and then I wait 12ms before I repeat the same letter.
    For test purposes, I repeat the same letter 50 times.
    Does anyone have some example on how he did?
    Thank you.
    This is my actual code
    ' Fuses
    @ DEVICE PIC16F690,FCMEN_OFF
    @ DEVICE PIC16F690,IESO_OFF
    @ DEVICE PIC16F690,BOD_OFF
    @ DEVICE PIC16F690,CPD_OFF
    @ DEVICE PIC16F690,PROTECT_OFF
    @ DEVICE PIC16F690,MCLR_OFF
    @ DEVICE PIC16F690,PWRT_OFF
    @ DEVICE PIC16F690,WDT_OFF
    @ DEVICE PIC16F690,INTRC_OSC_NOCLKOUT
    ' Registers
    CM1CON0     = %00000000 'Comparator 1 is OFF
    CM2CON0     = %00000000 'Comparator 2 is OFF
    ANSEL       = %00000000 'Disable analog inputs
    ANSELH      = %00000000 'Disable analog inputs
    ADCON0      = %00000000 'ADC is OFF
    OPTION_REG  = %10000000 'Pull-Ups disabled...
    TRISB       = %00000000 'All PORTBs are Outputs
    PORTB       = %00000000 'All PORTBs are Low
    WPUB        = %00000000 'All Weak Pullups on PORTB are Bisabled
    ' Defines
    ' Variables
    LED4            var PORTB.4
    LED5            var PORTB.5
    LED6            var PORTB.6
    LED7            var PORTB.7
    Counter_A       var byte
    LED_interval    var byte
    LED_interval    = 3
    Letter_interval var byte
    Letter_interval = 12
    ' Program
    LOOP:
        for counter_a = 0 to 50
            gosub letter_A
            PORTB = 0
        next
        pause Letter_interval
            gosub letter_M
            PORTB = 0
        next
            gosub letter_I
            PORTB = 0
        next
        goto loop
    ' Message
    LETTER_A:
        led4 = 0
        led5 = 0
        led6 = 1
        led7 = 1
        pause Led_interval
        led4 = 1
        led5 = 1
        led6 = 1
        led7 = 0
        pause Led_interval
        led4 = 1
        led5 = 0
        led6 = 1
        led7 = 0
        pause Led_interval
        led4 = 1
        led5 = 1
        led6 = 1
        led7 = 0
        pause Led_interval
        led4 = 0
        led5 = 0
        led6 = 1
        led7 = 1
        pause Led_interval
    LETTER_M:
        led4 = 1
        led5 = 1
        led6 = 1
        led7 = 1
        pause Led_interval
        led4 = 0
        led5 = 1
        led6 = 0
        led7 = 0
        pause Led_interval
        led4 = 0
        led5 = 0
        led6 = 1
        led7 = 0
        pause Led_interval
        led4 = 0
        led5 = 1
        led6 = 0
        led7 = 0
        pause Led_interval
        led4 = 1
        led5 = 1
        led6 = 1
        led7 = 1
        pause Led_interval
    LETTER_I:
        led4 = 1
        led5 = 1
        led6 = 1
        led7 = 1
        pause Led_interval
        led4 = 1
        led5 = 1
        led6 = 1
        led7 = 1
        pause Led_interval
        led4 = 1
        led5 = 1
        led6 = 1
        led7 = 1
        pause Led_interval
        led4 = 1
        led5 = 1
        led6 = 1
        led7 = 1
        pause Led_interval
        led4 = 1
        led5 = 1
        led6 = 1
        led7 = 1
        pause Led_interval
    Roger
    From what i feel, you could probably find a tons of example and explanation using 'propeller clock' in google.
    Your method seems workable. I never tried something like that so far.
    Default Flags
    Hi flotulopex,
    Nuts and volts did a project like this which displayed US and Canadian flags on a bike wheel, June 2005 issue. The article was based on kits by infinetix Corp in Spokan, WA. They did not publish any code but did publish flow charts as to how the software worked.
    JS
    Hi Mister_e,
    There some very cool ones out there, yes?
    JS
    T.Jackson's Avatar
    T.Jackson Guest
    What you're trying to do requires correct speed and timing. A project called Spin FX was published in the Silicon Chip magazine few years back. The article read great! There's still even KITS available for it. (Stock is very limited though)
    <a href="http://www.dse.com.au/cgi-bin/dse.storefront/4647d6c8069df9ae2742c0a87f9c074f/Product/View/K3005" target="_blank">Click here to purchase a KIT </a>.
    Jul 2005
    How are you getting this code to synchronize with the position of the wand?
    Say you wave it right and left over and over. You would want your code to start displaying letters when the wand ‘banks’ to the left side and begins to move to the right, that way as the wand sweeps left to right you draw the pixels of the letters where they are needed in space.
    As I read your code there is no synchronization between the drawing and the movement.
    To make something simple to try, make the top of the wand a pulled up input and tap it against a grounded post. This gives you a pulse when you’re far left; have the code wait for that pulse THEN (after a short pause) start to draw the pixels ONCE for each letter in turn, then stop and wait for the next synch pulse.
    The next trick is to make a cheap acceleration sensor to make this pulse for you from only the change in stick direction.
    Default well then, how does it really work?
    Yup ErnieM,
    I was thinking about this "when to start to wave" problem.
    This is also why I would have appreciated to get some code examples...
    In all website (many thanks to MisterE 'cause I didn't know how to call this type of gadget before his post) where I could find information, there is no mention about a mouvement sensor in the case of handheld models.
    My assumption was to repeat the message sequence endlessly and you modulate the wave speed to make it readable.
    Or is it not that way it works?
    So, if anybody else knows...
    Roger
    Yup ErnieM,
    I suppose it can go both ways...either you trigger it (mercury switch, IR LED, acclerometer, heck, maybe even a neuro-muscular-interface wired into your wrist), or your hand rocks in sync with the program, maybe dial it up or down with a pot or something.
    Apr 2006
    New Hampshire USA
    Lightbulb synchronized
    I always wanted to make a strip of LEDs that was on a truck body or mounted on an upright pole on a motor vehicle. This single strip of LEDs would be synchronized to the speed of the vehicle. People standing on the side of the road would see the full color “banner” poster, as it swooshed past them!
    Or
    Maybe, a single pole beside the highway. A single strip of LEDs that could be synchronized to the speed (read by RADAR) of the vehicle. The people moving by would see a full-length bill board, but the “sign” would be a single piece of conduit. No wind loading no blocking the scenery.
    Probably not enough speed for the illusion, but a fun “what-if” experiment.....
    -Adam-
  1. Code to control 4 LEDs and 2 servos
    Last Post: - 26th November 2008, 14:33
  2. Microcontroller with 2 way paging application problem
  3. Using LEDs as light sensors
    Last Post: - 30th December 2006, 23:19
  4. having problems with Hantronix 20x4 lcd
    By Rhatidbwoy in forum mel PIC BASIC Pro
    Last Post: - 22nd December 2005, 13:22
  5. 7 segment digit problem (using Mister E's code)
    By jmgelba in forum mel PIC BASIC Pro
    Last Post: - 9th September 2005, 21:25
