How do i get pwm oscillator with pic16c56a
Results 1 to 5 of 5
    May 2007
    Smile Re:
    Hi
    I tried on ur suggestions but i donot found any thing.
    Best regards
    mubashir
    T.Jackson's Avatar
    T.Jackson Guest
    Post
    You have to put a bit of effort into things yourself bud. Try generating some code to do what you want, submit it here if you still have problems and there's a good chance that someone will help.
    Quote Originally Posted by mubashir View Post
    Hi
    Best regards
    mubashir
    output portb.0
    low portb.0
    pause 10
    high portb.0
    pause 10
    there's your 50Hz output, 10ms low, 10ms high, 20ms total period...
    1 seconds / 20ms = 50Hz...
    Was it really that difficult?
  1. Half-bridge PWM with a 16F684 ?
    Last Post: - 17th January 2010, 23:18
  2. Variable PWM PIC18F2431
    By trr1985 in forum mel PIC BASIC Pro
    Last Post: - 12th June 2009, 07:03
  3. PWM 'channels ...what's that all about then!
    By HankMcSpank in forum General
    Last Post: - 23rd April 2009, 17:49
  4. PWM setting PIC16F887
    By Gevo in forum mel PIC BASIC Pro
    Last Post: - 12th June 2008, 08:24
  5. Tidying Up PWM Routine
    Last Post: - 21st February 2005, 01:26
