@dynamoben
Can you explain to me this code for 1 chanel?
it was yours i have found it in the forum
DimmerCount VAR WORD ; Location in DMX string
DMXStartAddr VAR WORD ; DMX start address
DMXStartCode VAR BYTE ; DMX Start code (Dimmer=0)
Dummy VAR BYTE
DMX_State VAR BYTE ; Stage of DMX reception
Valid_Break CON 1
Valid_SC CON 2
Valid_Data CON 3
Disable
INTERRUPT_SUB:
IF OERR Then
CREN = 0
CREN = 1 ; Clear Overrun Errors
High Err_LED ; Notify user of overrun error
DMX_State=0
EndIF
IF FERR Then
FERR = 0
DMX_State=Valid_Break
Else
GoSub RX_DMX_Data
EndIF
Dummy=RCREG ; Empty UART of junk data
Resume
RX_DMX_Data:
IF DMX_State=Valid_Break Then
HSerin 20,NoData,[DMXStartCode] ; Start code of 0 = dimmer data
IF DMXStartCode=0 Then
DMX_State=Valid_SC
Else
High Err_LED ; Notify user of Error in Start Code
DMX_State=0
EndIF
EndIF
IF DMX_State=Valid_SC Then
For DimmerCount=0 TO DMXStartAddr; Count incoming data bytes (frames)
Dummy=RCREG ; Read unwanted values
Next DimmerCount
DMX_State=Valid_Data
EndIF
IF DMX_State=Valid_Data Then
HSerin 20,NoData,[STR DataBuffer\Number_Of_Channels]
DMX_State=0
EndIF
IF DMX_State=0 Then
Resume
EndIF
GoTo RX_DMX_Data
NoData:
DMX_State=0
Resume
Enable
