How do I get 18f452 pin 10 set as digital input?
Results 1 to 11 of 11
    so basically you need everything digital right?
    ADCON1=7
    and for safety sake
    SSPCON1=0
    this have to do the trick.. if not, you have a faulty PIC, faulty hardware.. or i need another drink ... 5:00 AM Here... still trying to forget those beauties that Lerameur bring to the night club tonight... mmmmmm
    INCLUDE "EE_Vars.PBP"
    once you're done, please post some of your code that show/use that nice feature... at very least for others forum member benefit.. and Darrel's pleasure.
    jessey's Avatar
    jessey Guest
    Default Thanks Steve
    Hi Steve,
    That's great Steve, thanks for the code, I really appericate it. I'm off to work now (Saturday), I've worked every day this week and now the weekend!!.... Oh well. I'll be sure to post my code after I get a chance to try your suggestion and clean it up a bit. Give me a couple of days.
    Thanks Again
    jessey
    Apr 2006
    New Hampshire USA
    Thumbs up neat coding style
    Hi jessey,
    Quote Originally Posted by jessey View Post
    I have to mention; Your coding style is quite easy to read and contains a lot of helpful information. So even though you are fairly new to PICs you code style is extremely helpful to us beginners. I am learning from it, and looking forward to your code posting.
    -Adam-
    well commented/documented code is indeed the trick. Well done!
    jessey's Avatar
    jessey Guest
    Default Still can't get pin 10 configured properly?
    Quote Originally Posted by Pic_User View Post
    Hi jessey,
    -Adam-
    Hello Steve & Adam,
    Sorry for taking so long to post my code but I've been pretty busy lately and it took a bit to go through the program and try and make the comments make sense. I just hope you can follow the flow of the program. If you have any questions then feel free to ask.
    This program might be a little hard to follow because of all the Dummy variables that I used, I'm not sure if I'm using them correctly or if there's a better way of doing it but using the Dummy var's has saved me a lot of code space and the program seems to be working perfectly. Without them I definitely wouldn't have enough code space on my 18f452 for all the features I want to implement. There is still a lot I can do to save code space but its still a work in progress, I still have timing issues to resolve as well. Any comments or suggestions from anyone will be very much appreciated especially when it comes to using the Dummy variables.
    I didn't have time to go through Darrels Strings routine to comment it properly but I can say it works great. When I get all the features in my program that I want then I'll finish the Strings by including an overview of the programs features and instructions on how to set it up. Its great to have a manual programmed into the chip, better than written instructions because you can't loose them. In Darrels Strings I can get 142 prints in GetInstructions1 alone, plus probably well over 100 in the other GetInstructions ones that I'm using. That's a great routine Darrel and I thank you again for it.
    Oh, Steve I tried using SSPCON1=1 and I still can't seem to get pin 10 working as either a digital input or output. I tried it on a couple of different 452's with the same results?
    jessey
    jessey
    Very well commented code indeed...BUT...the code, as a whole, looks entirely too over-written, over-designed, over-complicated, for the end result. This almost looks like something written for the Space Shuttle or something
    At any rate, back to the PortE.2 thing...
    Back to the basics is all I can say. Get a fresh breadboard, get a fresh PIC, a push button and an LED. Put the button on PortE.2 with a pullup (or a pulldown, whatever works), put the LED on another Port, whichever you want. Write a program that makes the LED follow the button's input, and ONLY the button's input...like:
    button var porte.2:input button:led var portb.0: output led:led=0
    if button = 1 then LED = 1
    if button = 0 then LED = 0
    If that doesn't work right off the bat, then start playing with the config registers until things start working.
    I've read other posts from you, I know you've got a decent grasp on how to run these PICs. Sometimes a guy just forgets something stupid and silly and it kicks him in the arse for days...gotta break it back down to the basics.
    For all you know, the lead going to PortE.2 is open somewhere, or the switch itself is shot.
    jessey's Avatar
    jessey Guest
    Default I'm sure its not the bread board
    Hi skimask,
    Is the code that complicated? Yea I guess it is somewhat but what I was thinking to do when I was writing it, well for one code segment below:
    The Dummy_Water_Valve holds the value of Water_Valve_1 to 6 for PORTB.2 to PORTB.7 so I use the Dummy_Water_Valve var to turn On or Off any of the 6 Water valves. The same thing applies to the Dummy_Nutrient_Valve variable but with different PORT pins of course.
    I wanted to know if a Water Valve on PORTB.2 to PORTB.7 was involved in a watering cycle, so for that I'm using the Dummy_Water_Valve_Number variable. What happens is when a Moisture meter sends a request to start a watering cycle then its valve is turned on using the Dummy_Water_Valve var and at the same time the
    Dummy_Water_Valve_Number var is set to Is_Watering so the program can use this var to know that there's an active watering cycle happening for that Moisture Meter. One way that the watering cycle can be turned Off is when the Moisture Meter that started the watering cycle sends a + signal for 2500ms to stop the watering and that sets Dummy_Water_Valve = Is_Turned_Off and at the same time the Dummy_Water_Valve_Number = Is_Not_Watering so the program knows what's going on. The other way of turning off the watering cycle is to use the Dummy_Off_Tm timer and that's pretty straight forward, its just a timer that when set it enables the auto Off, it counts up to a set time and shuts off the watering cycle using the exact same code segment that the Moisture meter uses to shut Off the watering cycle.
    Using that logic then when we're implementing the watering cycle then we first check if the Dummy_Water_Valve_Number is watering and if so then if the Dummy_Water_Valve is On, then we implement the On_Time_counter or if the Dummy_Water_Valve is Off then we implement the Off_Time_Counter. Also (ELSE) if the Dummy_Water_Valve_Number is not watering then we just implement a Calibration Pause to maintain a one second time base for the timers.
    That seems pretty basic to me but that's only one segment of the code. What part of the code were you having problems following or think is over done or complicated (not that it isn't somewhat complicated)? I'm sure that some of the other beginners here might be interested, I know I would if you have the time to try and follow the flow of the program. If you (or anyone else here for that mater) finds a part of the code that's confusing or redundant then I'll try and explain my logic for that part and or change it to flow better.
    Back to the PortE.2 thing, I'm sure its not the bread board because when I set pin 10 to an output then I test a Led to make sure that its working then I touched the led directly on the port pin and it doesn't turn On/Off like it should. Real strange, I tried 4 different 452's and the same results, mind you they are all ones that are used but still? I'll try getting a few more new ones and play around with the config settings to see what results I get.
    jessey
    jessey
    That's the thing...you tested for an output, not an input. Have you tried something really silly like reloading PBP and MPLAB? Ya never know there either.
    As far as the '452 goes, you might want to switch over to a '4620, twice the code space, lot more ram, bunch more options, same price, almost 100% firmware compatible to the '452, and it is pin compatible with the '452. When I built my player, I started off with a 16F877, switched to a '452, then a '4620, all on the same PCB, and very little firmware change during the process.
    As far as the program goes, I'm not saying that what you wrote is crap...far from it. I can easily follow everything you want to do. I'm just thinking that a lot of what you wrote can be rewritten a lot smaller and more compact. If I get some time over this long weekend, I'll take a deeper look at the code and see what I can come up with. One thing you might want to do, and I don't know if it'll have anything to do with anything or fix anything, is move some of the blocks around...
    1-CONFIGs
    2-DEFINEs
    3-Variable assignments
    4-Jump over everything to the main loop
    5-Interrupt code and subroutines (don't forget the disable)
    6-Subroutines (don't forget the enable)
    7-Main Loop
  1. Is this a K Type sensor?
    Last Post: - 21st November 2009, 14:55
  2. lumex 4 line display
    By glkosec in forum mel PIC BASIC Pro
    Last Post: - 12th August 2009, 18:55
  3. 18f series chip locked up
    Last Post: - 11th August 2009, 08:27
  4. Digital Out on an A/D pin safe ?
    By mr.sneezy in forum mel PIC BASIC Pro
    Last Post: - 21st January 2009, 23:48
  5. 16f88 - pin RA4 as analog input
    Last Post: - 15th December 2006, 14:55
