Hello Steve & Adam,
Sorry for taking so long to post my code but I've been pretty busy lately and it took a bit to go through the program and try and make the comments make sense. I just hope you can follow the flow of the program. If you have any questions then feel free to ask.
This program might be a little hard to follow because of all the Dummy variables that I used, I'm not sure if I'm using them correctly or if there's a better way of doing it but using the Dummy var's has saved me a lot of code space and the program seems to be working perfectly. Without them I definitely wouldn't have enough code space on my 18f452 for all the features I want to implement. There is still a lot I can do to save code space but its still a work in progress, I still have timing issues to resolve as well. Any comments or suggestions from anyone will be very much appreciated especially when it comes to using the Dummy variables.
I didn't have time to go through Darrels Strings routine to comment it properly but I can say it works great. When I get all the features in my program that I want then I'll finish the Strings by including an overview of the programs features and instructions on how to set it up. Its great to have a manual programmed into the chip, better than written instructions because you can't loose them. In Darrels Strings I can get 142 prints in GetInstructions1 alone, plus probably well over 100 in the other GetInstructions ones that I'm using. That's a great routine Darrel and I thank you again for it.
Oh, Steve I tried using SSPCON1=1 and I still can't seem to get pin 10 working as either a digital input or output. I tried it on a couple of different 452's with the same results?
jessey
