Thanks for the tips. I will try them,and turn back with many other questions, I guess.
Hi, Ernie
I do not know where you buy your resistors ...
but my 1% 100 ppm ones from RAMTRONICS cost me ... 1.8 cent/ unit !!!
" Hobbyist " price ... of course.
You need more than just the resistors. You also need a suitable OP AMP for buffering. The more you Load the ladder down, the less usable resolution you'll have. R2/R ladders are old school stuff. Better to use the dedicated chip - having this knowledge is worth more.
Just an additional note I used the LTC1453 DAC and it was easy to use and worked great I used it to drive an analog devices 4-20mA convertor chip.
hope this is of some use to somebody.
thanks again for all your help and patience
'LTC1453 DAC Setup
output portC.5 'clock pin
output portA.2 'data pin
output portA.3 'CS/Load pin low to enable clock high to load data to dac output
symbol DCK = portc.5
symbol DDA = portb.0
symbol DCS = porta.2
DAOut var word ' daoutput variable
DAspan var word ' Da span adjust variable
Volt1 var word ' Raw data variable
' Get Load Value and output to DAC 0-2.5 vdc for range of 12 bits
DAC1: low DCS
DAout = volt1*DAspan ' voltage output raw signal scaling
DAout = div32 1000
shiftout DDA,DCK,1,[DAout\12]
HIgh DCS
