Digital to Analog Converter
Results 1 to 9 of 9
Threaded View
  1. #2
    Hi, Kutsi
    You've two ways for the DAC ...
    if using 8 bits output ( for a motor it's far enough !!! ) ... then use a full port with a 1% resistors R/2R ladder to generate the voltage output ... ( a little AOP buffer will make it perfect ... )
    no need a MAX 512 or else here ...
    if using more bits, a LTC 1257 or 1451 from Linear will work fine, you're not to use all your DAC resolution ... and can send two "0"s as LSBs past the ADC 10 bits you've read !!!
    PS: PWM freq. to use depends upon the motor technology, but there's always some switching noise you can hear in the windings ... but low speed torque obtained is better ( easier to see smoke if overloaded too !!! )
    DC won't produce any noise ... but will give poor starting torque, if there's no rpm regulation implemented. a current protection is easier to add in this way ...
  1. analog and digital
    Last Post: - 10th June 2008, 03:40
  2. PortA analog and digital IO
    By krohtech in forum mel PIC BASIC Pro
    Last Post: - 30th November 2007, 03:25
  3. Replies: 2
    Last Post: - 14th April 2006, 10:42
  4. AD7391 digital to analog converter
    By srob in forum mel PIC BASIC Pro
    Last Post: - 12th November 2005, 13:07
  5. Analog pins for digital input
    Last Post: - 9th September 2005, 01:32
