i' using the following code to read 2 LDRs' and change the direction of a small robot. The code is based on the tutorial: http://www.rentron.com/Micro-Bot/CDS.htm
Code:eyes: gosub check_LDR ' get LDR RC values select case light_state case 1 IF LDR_Right_Val > LDR_Left_Val THEN 'if right brighter than left if panic_flag = 1 then 'is it in hide mode? eyes_output = right 'yes - right else eyes_output = left 'no - left end if 'ENDIF else light_state = 2 'goto next state end if case 2 if LDR_Left_Val > LDR_Right_Val THEN 'if left brighter than right if panic_flag = 1 then 'is it in hide mode? eyes_output = left 'Yes - left else eyes_output = right 'No - right end if else light_state = 3 'goto next state end if case 3 light_state = 1 'goto the first state eyes_output = idle 'idle end select return 'return to start check_LDR: HIGH portb.6 'Right_LDR 'Make right CDS pin high PAUSE 3 ' Let cap charge RCTIME portb.6, 1, LDR_Right_RCdata ' Time & record discharge time HIGH portb.7 'Left_LDR 'Make left CDS pin high PAUSE 3 ' Let cap charge RCTIME portb.7, 1, LDR_Left_RCdata ' Time & record discharge time LDR_Right_Val = NCD LDR_right_RCdata LDR_Left_Val = NCD LDR_left_RCdata return
i'm using a 220ohm resistor, with 0.1uF caps. The LDRs rated 27k - 94k.
The code works in that if one LDR is covered the the robot turns as required.
However In ambient light it doesnt find the brightest source of light.
Can anyone help with sugestions to improve the sensitivity..
any help is greatly apriciated
thanks
jim
