12f629 Eeprom
Results 1 to 6 of 6
Thread: 12f629 Eeprom
    Fayetteville Arkansas
    Default 12f629 Eeprom
    I have never used EEPROM before and am confusing the **** out of myself reading the data sheet. All I'm trying to do is save and read a couple of variables. One will range from 0-6 while th other would be a 0 or 1. If anyone has a simple code example I would really appriciate the help.
    There's many ways, but assuming the PBP statements and you want to do it at run-time without having default value in the EEPROM, you need to use WRITE and READ.
    Steve that was what I was trying with Write address, value. Maybe I'm confusing myself with the address. On page 49 of the data sheet it also gave a list of requirements and I was getting syntax errors. What I'm trying to do is increment a value using a button and write it to EEPROM and be able to read it.
    O.K. the 12F629 have 128 bytes of EEPROM, so the address range is between 0 and 127. PBP WRITE handle the PIC address for you.
    try this
    <font color="#000000">        <font color="#008000">'
            '       Pic Configuration
            </font>@ __CONFIG _INTRC_OSC_NOCLKOUT &amp; _WDT_ON &amp; _PWRTE_ON &amp; _MCLRE_OFF &amp; _BODEN_ON
            '       Hardware configuration
                    '       I/Os
                    </font>TRISIO = %11111110  <font color="#008000">' GP0 As output, others TO input
                    '       Comparator
                    </font>CMCON = 7           <font color="#008000">' Disable comparator
            '       Hardware assignment
                    '       User control
                    </font>PB1     <font color="#000080">VAR </font>GPIO.1
                    LED     <font color="#000080">VAR </font>GPIO.0
            '       Software variables
            </font>AddressCounter  <font color="#000080">VAR BYTE
            </font><font color="#008000">'
            '       Software/Hardware initialisation
            </font>AddressCounter = 0
            LED = 0
            <font color="#000080">PAUSE </font>100   <font color="#008000">' osc settle time
            '------------------------------&lt; Main program &gt;-----------------------------------
    </font>Start:
            <font color="#000080">WHILE </font>AddressCounter!=128
                <font color="#000080">IF </font>PB1 = 1 <font color="#000080">THEN
                    WRITE </font>AddressCounter,AddressCounter
                    LED = 1
                    <font color="#000080">WHILE </font>PB1 : <font color="#000080">WEND
                    PAUSE </font>100
                    LED = 0
                    AddressCounter = AddressCounter + 1
                    <font color="#000080">ENDIF
                WEND
            </font>LED = 1
    SpinHere:
            <font color="#000080">GOTO </font>SpinHere
    </font>
    Each time you'll press on the push-button attach to gpio.1, it will write to the EEPROM. Once the EEPROM is full, the LED will stay ON.
    Once done, if i read the pic, the EEPROM show...
    <IMG SRC="http://www.picbasic.co.uk/forum/attachment.php?attachmentid=1609&stc=1&d=117864751 5">
    Sucessfull!
    Thank you Steve. Let me see where I can go from here.
    Thanks again Steve. It was the address that had me confused and your example cleared it up for me.
    Butch
    Last Post: - 18th February 2010, 14:46
  2. How to define constants that specify eeprom addresses
    By DwayneR in forum mel PIC BASIC Pro
    Last Post: - 8th December 2009, 04:07
  3. Problem with I2C EEPROM addressing
    By Atom058 in forum General
    Last Post: - 3rd November 2009, 03:17
  4. How to write/read strings EEPROM/LCD
    By g-hoot in forum mel PIC BASIC Pro
    Last Post: - 11th February 2007, 06:26
  5. word variable to 25lc640
    By TONIGALEA in forum mel PIC BASIC Pro
    Last Post: - 6th July 2004, 19:59
