Complete Keypad Example
Results 1 to 19 of 19
    T.Jackson's Avatar
    T.Jackson Guest
    Post
    I haven't seen Mister_e's keypad routine. Anyone have the link handy?
    T.Jackson's Avatar
    T.Jackson Guest
    Post First paragraph under schematic.
    Notes & Eratta:
    First paragraph under schematic I state: Also, it's worth while noting that the 4MHz crystal isn't critical, you could if you wish use an RC oscillator. You'll save a few bucks. <hr/>*This assumes that you won't be connecting the keypad to the serial port. A crystal is mandatory if you intend to build the project entirely as presented.
    But that's OK,
    new entries (ways) are welcome!
    Jun 2007
    TÜRKİYE
    Default TeŞekkürler
    güzel çalışma teşekkür ederim
    TÜRKİYE
    Quote Originally Posted by langtolan.com
    güzel çalışma teşekkür ederim can't be found
    Désolé je ne comprends pas
    Sayzer?
    Jul 2007
    paris
    Default Spy
    I find the T.Jackson program very well, but I need a routine or a help for a program, to make a spy, to see example thank you
    Col_1 VAR PORTB.4
    Col_2 VAR PORTB.5
    Col_3 VAR PORTB.6
    Row_1 VAR PORTB.3
    Row_2 VAR PORTB.2
    Row_3 VAR PORTB.1
    Row_4 VAR PORTB.0
    Col_1/ Row_1 = 1
    Col_1/ Row_2 = 4
    Col_1/ Row_3 = 7
    Col_1/ Row_4 = *
    Col_2/ Row_1 = 2
    Col_2/ Row_2 = 5
    Col_2/ Row_3 = 8
    Col_2/ Row_4 = 0
    Col_3/ Row_1 = 3
    Col_3/ Row_2 = 6
    Col_3/ Row_3 = 9
    Col_3/ Row_4 = #
    CASE 1
    Col_1 = 0
    Row_1 = 0
    Row_2 = 0
    Row_3 = 0
    Row_4 = 0
    '// 1 Key
    IF Row_1 = 0 THEN
    IF Allow_Key = 0 THEN
    Key_Press = 1
    Allow_Key = 1
    '// 4 Key
    IF Row_2 = 0 THEN
    Key_Press = 4
    Allow_Key = 1
    '// 7 Key
    IF Row_3 = 0 THEN
    Key_Press = 7
    Allow_Key = 1
    '// * Key
    IF Row_4 = 0 THEN
    Key_Press = 42
    Allow_Key = 1
    Scan_Col = 0
    http://www.electroniquepratique.com/...idMg=44&id=523
    Mini espion pour clavier de PC
  1. 4x4 keypad Help
    By aaliyah1 in forum mel PIC BASIC Pro
    Last Post: - 5th October 2010, 17:34
  2. HARDWARE I2C SAMPLE CODE question
    Last Post: - 16th June 2009, 22:07
  3. Keypad input test
    By Kalind in forum mel PIC BASIC Pro
    Last Post: - 8th October 2008, 05:00
  4. Need help in matrix keypad coding
    By rano_zen06 in forum mel PIC BASIC Pro
    Last Post: - 24th May 2008, 14:16
  5. novice need help for a security keypad
    By davleo in forum mel PIC BASIC Pro
    Last Post: - 17th November 2003, 22:54
