Division with some decimal
Results 1 to 16 of 16
    Jul 2005
    Ferrara - Italy
    Unhappy Division with some decimal
    Hi to everybody!
    I would have the necessity to perform the following division in PIC Basic, but I don't know from how stings to depart.
    A = B / 5,58
    B is a constant
    I would have the necessity to visualize the result on a display LCD also visualizing 2 decimal.
    Can someone help me?
    Thanks everybody
    Quote Originally Posted by Darklakebridge7 View Post
    Hi to everybody! I would have the necessity to perform the following division in PIC Basic, but I don't know from how stings to depart.
    A = B / 5,58 B is a constant
    I would have the necessity to visualize the result on a display LCD also visualizing 2 decimal. Can someone help me? Thanks everybody
    You do know that PBP does NOT deal with fractions and decimals...right?
    a var word
    b var word
    'start with a number in b
    1 - b = 655 ' maximum value in b is 655, otherwise word variable b will overflow
    2 - b = b * 100 'shift the decimal point over to right 2 places temporarily
    3 - a = b / 558 'constant value of 5.58 also has it's decimal point shifted over by 2 places
    1 - b = 655 (given)
    2 - b = 65500 (closest you can get without overflowing a word value)
    3 - a = 117 ( 65500 / 558, PBP doesn't do fractions)
    Do a search on 'decimal' and 'fraction' here and you'll find some stuff. Otherwise, download the floating point math routines from microchip if you need good accuracy.
    Hangover, Germany
    Wink
    While B is a constant,
    just type it to your desktop-calculator and place the result inside a LCDOUT-command. ;-)
    Because, if B is a constant and 5,58 too - the result "A" is another constant. You don't need any calculation in runtime...
    Quote Originally Posted by BigWumpus View Post
    Oh..Hey...Good point!
    Missed that entirely! DOH!
    That really would save a lot of calculation time wouldn't it...
    Jul 2005
    Ferrara - Italy
    Unhappy
    Hi boys!
    I have been wrong to expose the problem!
    I would have the necessity to divide the variable "B" for the number 5,58 and subsequently to visualize the result "A" on LCD.
    My very problem is the following:
    A = B / 5,58
    Excuse the error! Everybody can help me??
    New Hampshire
    Not knowing the size of B, I've used DIV32. B can be any integer up to 65534.
    A VAR WORD
    B VAR WORD
    A = B * 100 'A is temporary storage of computation
    A = DIV32 558 'using DIV32... B can be any integer up to 65534
    A = A / 100 'final result is placed in variable A as an integer... any
    'remainder will be discarded.
    Hope this helps,
    Ross
    Never enough knowledge to be called intelligent but just enough knowledge to be considered dangerous!
    I like that! :-)
    A = B / 5,58
    Now then, where were we?
    Darklakebridge7,
    An easy way to think about it is to look at how you would "Name" the numer.
    For instance,
    5.58 is 558 hundredth's of whatever it is.
    So if you multiply by 558, then divide by 100 (hundredths), you end up with the correct answer. (integers only)
    B = 123
    A = B * 558
    A = DIV32 100
    Piece of Pie, or was that cake.
    Jul 2005
    Ferrara - Italy
    Red face
    Darklakebridge7,
    For instance,
    B = 123
    A = B * 558
    A = DIV32 100
    Hi to everybody!
    Forgive me, but I am new and I have some problem with the language English! Could you recommend me a some good book of PIC Basic?
    A special thanks to all those people that have helped me to resolve my problem!
    No need for a book! Forum and head-banging is more than enough!
    New Hampshire
    A VAR WORD
    B VAR WORD
    TNTH VAR BYTE
    HUNDTH VAR BYTE
    TNTH = A DIG 1 'GRAB THE "TENS" DIGIT FROM "A"
    HUNDTH = A DIG 0 'GRAB THE "ONES" DIGIT FROM "A"
    A = A / 100 'final result is placed in variable A as an integer... any 'remainder will be discarded.
    LDCOUT $FE,1 'CLEAR DISPLAY
    LCDOUT "A = ",#A,".",#TNTH,#HUNDTH
    I think that would give you what you want.
    Ross
    I like that! :-)
  1. variable + decimal
    Last Post: - 18th August 2009, 15:21
  2. Binary Coded Decimal
    By -Dan- in forum mel PIC BASIC Pro
    Last Post: - 25th May 2009, 10:23
  3. 16bit variable and degrees conversion
    Last Post: - 2nd May 2005, 18:27
  4. Decimal to binary conversion
    By Demon in forum Code Examples
    Last Post: - 25th February 2005, 21:05
  5. Convert a word variable to decimal
    Last Post: - 4th December 2004, 21:02
