Problem with A port on 18F2550
Results 1 to 19 of 19
    This is for a other project, it's a normal 5V operation system.
    The line where you talk about is not needed.
    make sure that there's no possible Brown-out reset @20MHz and @3 V. Usually the datasheet show the minimum voltage for a given crystal speed.
    EDIT: nevermind.. misread your post.
    well you'll need to post your Config Fuses line OR send your compiled .HEX files.
    Make sure your ADCON setting is good as well.
    I Use the following A ports:
    Input1 VAR PORTA.0 'input
    Relais1 VAR PORTA.5 'output
    Data_In VAR PORTA.4 'serial data
    LEDRood VAR PORTA.2 'output
    I use the following adcon settings:
    LATA = 0
    ADCON1 = 7 'poort set as digital
    ADCON0 = 0
    ADCON2 = 0
    TRISA.1 = 1 'Input
    TRISA = 255
    Fuses are set:
    http://www.ttalens.com/images/picbasic/fuses1.JPG
    Does the ">Start<" go out the serial port about every 2 seconds or so?
    This is a one time operation.
    Quote Originally Posted by NL2TTL View Post
    I know it's a one time operation. That's the way you've written it in the program.
    I'm asking if, while the program is in operation, do you get the ">Start<" out of the serial port about every 2 seconds or so?
    Yes every 2 seconds
  1. Array problem (18F2550)
    By Ronald123 in forum mel PIC BASIC Pro
    Last Post: - 8th January 2008, 18:47
  2. Setting up Port b for I2C on 18f2550
    By rjones2102 in forum mel PIC BASIC Pro
    Last Post: - 2nd October 2007, 20:22
  3. Microcontroller with 2 way paging application problem
  4. PWM problem CCP2 port
    By NL2TTL in forum mel PIC BASIC Pro
    Last Post: - 19th September 2006, 23:34
  5. COM port problem
    By andys280176 in forum Serial
    Last Post: - 19th January 2006, 16:42
