Reading Program back from PIC
Results 1 to 8 of 8
    Just sit your PIC in your PIC programmer, then read it. This will give you .Hex code which you can translate in ASM in MPLAB.... well MPLAB had this function in the past. Seems V7.60 lost it... or i'm still lost in the clouds.
    Unfortunately, there's no way to convert the ASM to PBP ... directly
    Talking Being a "hard day's Night" ???
    Hi, Steve
    You forgot to tell our friend all his variable names are lost ... just memory locations left.
    No problem in V7.60 ( just some strong coffe for you ... NO MORE BEERS !!! ) just think to choose the right tab on the left down side of the program window.
    To save the file ( aha .......) re-program the chip ( or another) with this file, and then right click on the window and choose EXPORT ...
    I've not found how to export an hex file whithout programming a chip before ...
    That's all !!!
    Amitiés d'Outre-Atlantique
    yeah click on op-code tab... my mistake... always worth to move the program memory windows a little bit more to the top of the screen to see the whole thing.. oops.. this confirm i was right to call a taxi to get back home tonight... ils ont des chapeaux ronds... burp... vive les bretons!!! Hick!
    Nov 2006
    Brooklyn,NY
    Default Reading Program back from PIC
    I am still missing something here. "Put PIC in programmer and read it?"
    I am using the Melabs U2 programmer along with the Melabs Lab-X1 board to program the PIC.
    "Still in the dark."
    Quote Originally Posted by schlaray View Post
    Programmer software has a bunch of functions in the menu's. I haven't used the U2 programmer, but I suspect they're all the same (but different), but based on my Warp13a programmer software, I can:
    Program a complete PIC
    Program just the code memory of a PIC
    Program just the eeprom memory of a PIC
    Program just the Config Registers of a PIC
    Erase the whole PIC
    Erase just the program memory
    Erase just the EEPROM
    Verify the whole PIC
    Verify just the code memory
    Verify just the EEPROM
    Verify just the Config Registers
    Read the whole PIC
    Read the program memory
    Read the EEPROM
    Read the Config Registers
    EDIT: Just took a look...It's right there under the 'Program' menu...labelled as "READ Ctrl+R"
  1. Making Program Code Space your playground...
  2. pic to pic ir link versus wired link : help please anyone
    Last Post: - 30th May 2008, 21:01
  3. Help writing pic program with i/p o/p hold delay
    By g7jiq in forum mel PIC BASIC Pro
    Last Post: - 27th May 2008, 21:58
  4. Replies: 14
    Last Post: - 26th September 2007, 05:41
  5. Output PIC module
    By freelancebee in forum mel PIC BASIC Pro
    Last Post: - 12th September 2005, 20:10
