Hello,
These are not really Picbasic Pro questions, but it's Picbasic Pro I'm using and I don't know where else to ask! Still learning
Am I right in thinking that if you supply a + and - ref to the RA2 and RA3 pins that the same return count applies to a smaller voltage range therefore making the measurement a higher resolution one and more accurate?
Can you supply only the RA3+ reference and leave the RA2 nc?
If I wanted a + ref voltage of 2.5v, would the normal way to do this be by a voltage divider (couple of resistors)?
What I'm trying to do is get a high resolution and accurate voltage measurement between around 2-4.8volts on a 16f877
Thanks.
