Problem with UART... here is a real challenge
Results 1 to 8 of 8
    HSerIn doesn't need to be used in an interrupt.
    If you've got going what I think you've got going...
    When your interrupt trips, you've got a character in the receive register. When you get into your interrupt routine, the HSerIn line will wait for the next character, not get the one that's already in the receive register.
    And besides that, you're ON INTERRUPT doesn't get enabled until the end of the program (3rd line from the end of your code), which it will never reach.
    errr... HEX2 wait for two character, RCIF=0 is is a read only. This bit is cleared when you read RCREG untill the USART buffer is empty (HSERIN should take care of it)
    if this program work with Hyperterminal and not on another software, we need to know what's the other software. Could be handy to have a LCD attach to your PIC and display the incoming data.
    mmm... really sure of it???
    I guess I really never paid attention, but section 9 says they aren't enabled by default...I suppose I could be wrong...
  1. Problem with ASM IRQ using FSR0 on PIC18F252
    By mytekcontrols in forum mel PIC BASIC Pro
    Last Post: - 11th March 2008, 21:48
  2. Problem using Microloader and Uart Comm at the same time
    By guanerrr in forum mel PIC BASIC Pro
    Last Post: - 3rd August 2007, 10:31
  3. USART Problem , but don't know where, in pc? or in PIC?
  4. 1 slave 1 master 1 MAX232 1 problem ?
    Last Post: - 31st July 2005, 23:59
  5. weird 12F629/675 problem
    By peterdeco1 in forum mel PIC BASIC Pro
    Last Post: - 7th October 2004, 02:08
