Problem with UART... here is a real challenge
Results 1 to 8 of 8
    Feb 2007
    Smile thanks
    Tomorrow I will publiesh the code don`t have it with me..
    Feb 2007
    Default MY code that dosen`t fuction
    ' Defines for USART
    INCLUDE "bs2defs.bas"
    DEFINE HSER_RCSTA 90h
    DEFINE HSER_TXSTA 20h       '24h
    DEFINE HSER_BAUD 9600		'9600 baud
    DEFINE HSER_SPBRG 25        'No estaba
    ' Registros timer
    RCIF	VAR	PIR1.5			' Alias RCIF (USART Receive Interrupt Flag)
    OERR	VAR	RCSTA.1			' Alias OERR (USART Overrun Error Flag)
    CREN	VAR	RCSTA.4			' Alias CREN (USART Continuous Receive Enable)
    T0CS	VAR OPTION_REG.5
    PSA  	VAR OPTION_REG.3
    PS0  	VAR OPTION_REG.0
    PS1  	VAR OPTION_REG.1
    PS2  	VAR OPTION_REG.2
    ' Declaracion de variables
    valor1      VAR WORD        ' tiempos Timer
    valor2      VAR WORD
    valor3      VAR WORD
    estado      VAR BYTE        ' variable para disparar timer
    char0       VAR BYTE        ' b0 dato a decodificar
    char1       VAR BYTE        ' b1 dato a decodificar
    char2       VAR BYTE        ' b2 dato a decodificar
    char3       VAR BYTE
    i           VAR BYTE        ' Contador
    string      VAR BYTE[20]    ' Paquete Recepcion
    TMR0Count   VAR WORD
    c           VAR BYTE
    ' Configuracion de puertos
    TRISB= %00100111
    ' Configuracion inerrupciones
    INTCON = %11111000				' Registro para habilitar las interrupciones
    ON INTERRUPT GoTo serialin      ' AL realizarse interrupcion va ahi
    PIE1.5 = 1                      ' Habilitar interrupcion en USART
    ' Defines
    RBO       VAR PORTB.0
    RX        VAR PORTB.1
    TX        VAR PORTB.2
    interruption  VAR PORTB.3
    led       VAR PORTB.4
    RB5       VAR PORTB.5
    salida1   VAR PORTB.6
    salida2   VAR PORTB.7
    ' Inicio del programa
    i=0
    c=0
    char0=0
    char1=0
    char2=0
    string[0]=0
    string[1]=0
    string[2]=0
    string[3]=0
    string[4]=0
    string[5]=0
    string[6]=0
    string[7]=0
    string[8]=0
    string[9]=0
    string[10]=0
    string[11]=0
    PORTB=0
    Pause 1
    HSerout ["Port has Started Ok!!"]
    High interruption
    'Deparcing
    INICIO:
        IF i=255 Then
        High salida2
        For i = 0 TO 20
        IF string[i]=$52 Then
        char0=string[i]
        i=i+1
        char1=string[i]
        i=i+1
        char2=string[i]
        i=19
        EndIF
        Next i
        EndIF
    IF char0="R" AND char1="1" AND char2="1"   Then         'R11
         	High salida1
            char0=0
            char1=0
            char2=0
            string[0]=0
            string[1]=0
            string[2]=0
            string[3]=0
            string[4]=0
            string[5]=0
            string[6]=0
            string[7]=0
            string[8]=0
            string[9]=0
            string[10]=0
            string[11]=0
            Pause 2000
            i=0
            Low salida1
            Low salida2
        EndIF
    GoTo INICIO
    Disable	interrupt					' Don't check for interrupts in this section
    serialin:
    		HSerin  [HEX2 b0]
            IF b0 = $7C Then
            GoTo jump
            EndIF
            string[c]=b0
            c=c+1
            RCIF=0
            Resume
    jump:   RCIF=0
            c=0
            i=255
            Resume
    Enable interrupt
    HSerIn doesn't need to be used in an interrupt.
    If you've got going what I think you've got going...
    When your interrupt trips, you've got a character in the receive register. When you get into your interrupt routine, the HSerIn line will wait for the next character, not get the one that's already in the receive register.
    And besides that, you're ON INTERRUPT doesn't get enabled until the end of the program (3rd line from the end of your code), which it will never reach.
    errr... HEX2 wait for two character, RCIF=0 is is a read only. This bit is cleared when you read RCREG untill the USART buffer is empty (HSERIN should take care of it)
    if this program work with Hyperterminal and not on another software, we need to know what's the other software. Could be handy to have a LCD attach to your PIC and display the incoming data.
    mmm... really sure of it???
    I guess I really never paid attention, but section 9 says they aren't enabled by default...I suppose I could be wrong...
  1. Problem with ASM IRQ using FSR0 on PIC18F252
    By mytekcontrols in forum mel PIC BASIC Pro
    Last Post: - 11th March 2008, 21:48
  2. Problem using Microloader and Uart Comm at the same time
    By guanerrr in forum mel PIC BASIC Pro
    Last Post: - 3rd August 2007, 10:31
  3. USART Problem , but don't know where, in pc? or in PIC?
  4. 1 slave 1 master 1 MAX232 1 problem ?
    Last Post: - 31st July 2005, 23:59
  5. weird 12F629/675 problem
    By peterdeco1 in forum mel PIC BASIC Pro
    Last Post: - 7th October 2004, 02:08
